Nittro Drag radials users?
Old Sep 4, 2002 | 10:33 AM
racer rx's Avatar
To you guys using Nitto Drag Radials...
What kind of 60 fts drag times are you getting?
And what is the best size to go with our 3rd gens?
thanks
jc.
Old Sep 4, 2002 | 10:53 AM
ttpowerd's Avatar
HARRRRRRRRR
I have them but my car is still in the garage waiting on other parts before it will even run Can't say I've tested them yet
Old Sep 4, 2002 | 10:56 AM
jspecracer7's Avatar
1JZ powered
Re: Nittro Drag radials users?
thanks
jc.
If this helps...I dump the clutch at 6500 RPMs with 275/40 17 Nitto 555R drag...they go "Screch"...about that short...and I'm hole shoted!
Old Sep 4, 2002 | 11:36 AM
racer rx's Avatar
jspecracer? What 60 ft. time are you getting with those?
jc.
Old Sep 4, 2002 | 11:41 AM
ttpowerd's Avatar
HARRRRRRRRR
also what kind of diff. are u using?
Old Sep 4, 2002 | 02:48 PM
twinturboy's Avatar
i use 245/50-16 on the stock wheels...1.8 60ft without burnout.
Old Sep 4, 2002 | 03:12 PM
racer rx's Avatar
Hi Twinturboy,
Why do you not perform a burnout?
I'm sure the Nitto will hook better if you did...
jc.
Old Sep 4, 2002 | 04:09 PM
Import Convert's Avatar
Hi Twinturboy,
jc.
That is not true with all street tires. Most actually perform better without a burnout or a mild one at most.
Old Sep 4, 2002 | 05:59 PM
racer rx's Avatar
Quote from Import Convert,
This Thread is about Drag radials not regular street tire.
And I take it you have never raced your car with Drag Radials... you should try it... it is a quite a rush.
jc
