idiot lights flash on when I hit a bump?
Old Sep 3, 2002 | 06:45 PM
goodspeed's Avatar
Lightbulb idiot lights flash on when I hit a bump?
ever since I put my new engine back in ....yeah, it actually works now!!!....
anyway, everytime I hit a bump, all the idiot lights flash off and on???? It must be something with the wiring harness?? Anyone else experience this problem?
thanks
Old Sep 3, 2002 | 06:58 PM
TurboSmoke's Avatar
Getting Boosted
sounds like there is a few wires loose and are rubbing together
Old Sep 3, 2002 | 07:01 PM
Rxmfn7's Avatar
Do a barrel roll!
Mine does that sometimes, its not all the lights though, just my clock and the ones that should be on at that time, low fuel or something. I think its bad solders on the idiot lights.
Old Sep 3, 2002 | 08:19 PM
Amur_'s Avatar
Refined Valley Dude
They're flashing cuz for a sec the electrical power's cut. It happens to me when I hit hard bumps. Check for loose wires, particularly ground wires. Check the big ones first, starting at the battery.
Old Sep 3, 2002 | 08:29 PM
jacobcartmill's Avatar
just dont care.
check the little plug that is right behind the drivers' side headlight right under the corner of the hood. there is one little black plug that is the power plug for the drivers' side side marker light. if ALL of yours are going out, that is a different story. if you have a haynes manual, it has a good wiring diagram of the wires that come off the cpu. the parking lights are part of the CPUs responsibility. i would check the wiring diagram...
Old Sep 3, 2002 | 08:31 PM
just dont care.
oh ****, you said idiot lights... i thought you meant parking lights. i think amur is right about that one, probably just something grounding in and out... check all the grounds and also check the plug to make sure its not fucked.
Old Sep 3, 2002 | 08:56 PM
Loose wire.... now the fun comes from finding which one.
Kruel13
24
Sep 16, 2015 09:08 AM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
