External differences w/ jspec engines?
Old Sep 3, 2002 | 11:16 AM
DomFD3S's Avatar
Mod Powers...gone!
Ok, I know the differences between the US S4 engines. My question is...are there differences w/ the Jspec S4 engines that will help me identify the year of the engine. I have a 88 Turbo II. I was told by the previous owner that he swapped in a Jspec engine in it (supposedly an 88), but he was unsuccessful in getting it to run.
Engine would crank, but wouldn't start. So, I'm in the process of figuring out if he wired up the car properly or not.
Any help or suggestions on checking the possible year of the engine (and whether it is US or Jspec) would be greatly appreciated.
Old Sep 3, 2002 | 02:51 PM
DomFD3S's Avatar
Mod Powers...gone!
I know someone here knows the answer. Dave? Ted?
Old Sep 3, 2002 | 02:56 PM
DaleClark's Avatar
RX-7 Bad Ass
To tell if it's an '87-88 engine or an '89-91 engine, look for the knock sensor - if it's on the center iron housing, it's an '87-88. If it's on the rotor housing above the spark plugs, it's an '89-91.
The only real differences between Jspec and US-spec motors are in the intake manifold, throttle body, and the like, which may have been swapped out.
I'd just start on the typical no-start issues - vaccuum leaks, flooded engine, and timing not set right.
Dale
Old Sep 3, 2002 | 03:13 PM
88turborx7's Avatar
Look at the oil metering pump in the bottom right front corner. If there is a wiring harness coming out of the bottom of it then it's an 89-91, if not, then it's mechanical and an 87-88.
Old Sep 3, 2002 | 11:10 PM
Scott 89t2's Avatar
SOLD THE RX-7!
hmm the TB is different? I am about to buy one to port and swap onto mine. whats the diff?
hmm I just thought of something. throttle cable pulling from other side of car?
Old Sep 3, 2002 | 11:58 PM
FC Drifter's Avatar
Damaged Little F*cker
the 89+ tb is setup to have dual TPS. some vac lines are also different.
Old Sep 4, 2002 | 12:09 AM
Icemark's Avatar
No EGR valve on the Jspecs
Old Sep 4, 2002 | 12:15 AM
SonicRaT's Avatar
Super Raterhater
not to mention the BAC doesn't have a screw to adjust idle on the j-specs, also the intercooler says Rotary Turbo, not turbo II
Old Sep 4, 2002 | 03:13 PM
Scott 89t2's Avatar
SOLD THE RX-7!
hello Dale
what's the diff between US and J-spec TB's ??
Old Sep 5, 2002 | 01:39 AM
Scott 89t2's Avatar
SOLD THE RX-7!
grrr
Old Sep 5, 2002 | 02:03 AM
Funklord's Avatar
the IC on a j-spec says "rotary"
Old Sep 5, 2002 | 02:10 AM
SonicRaT's Avatar
Super Raterhater
Scott: I got a series 5 jspec TB, if you want I can take some pictures of it and we can compare (I'm not aware of any differnces)
Old Sep 5, 2002 | 02:15 AM
Scott 89t2's Avatar
SOLD THE RX-7!
it won't help much unless you can get some pics of a US one too cause mines on my car
Old Sep 5, 2002 | 02:17 AM
SonicRaT's Avatar
Super Raterhater
hahaha, good point I think the only difference was the number of vacuum nipples, I think the US has 4 and the jspec has 3. That's the ony difference I noticed at least.
Old Sep 5, 2002 | 02:20 PM
SLOWT2's Avatar
From: new hampshire, middleton(a town so small we have no conveince stores)
the j-spec engines are backwards, the fuel system runs backwards.
Old Sep 5, 2002 | 02:37 PM
DaleClark's Avatar
RX-7 Bad Ass
Originally posted by Scott 89t2
hello Dale
Hello!
The major difference on the throttle body is the Jspecs have a primary throttle stop adjustment screw that looks kind of like the TPS adjustment screw. They let you play with the primary throttle stop in Japan . On the US throttle body, there's a small jam nut on the primary throttle stop.
Besides that, they're pretty much identical.
Dale
Old Sep 5, 2002 | 02:39 PM
DaleClark's Avatar
RX-7 Bad Ass
The '89-91 US motors don't have EGR either, so it's not a good indicator.
The examples I gave above are to identify the *core* motor, not the stuff that's bolted onto it, which can easily be swapped over during an engine install.
Dale
Old Sep 5, 2002 | 02:58 PM
Icemark's Avatar
Ah good point... I had forgotten all about that
Old Sep 8, 2002 | 12:59 PM
Barwick's Avatar
SCCA Rookie
you mean they pull fuel out of the air and put it in the gas tank?
Old Sep 8, 2002 | 07:29 PM
SLOWT2's Avatar
the primary and second rails are switched
like when you do a nos fogger kit the line you have to tap for the fuel feed is diffrent cause the rails are switched
Old Sep 9, 2002 | 12:51 PM
GLHS's Avatar
Shelby Tuner & FC badass
I got a Jspec engine one time, that had a taller intake, and larger turbo and the manfold had no emmissions nor did it have a brake vacuum hole.
I was told by a Japanese guy who sold me the engine, that it had 220 hp stock!
Old Sep 9, 2002 | 01:08 PM
turboGXL's Avatar
Just to clear things up, the jspec 89-91 TB has 0 vaccum nipples on it. The only vacuum nipples close to the TB are on the UIM, there are 6 of them. The jspec TB, has the same throttle cable hook-up as the US spec. The primary idle screw was also mentioned, pretty cool thing to have, you can actually adjust the idle with the IC on =). Why does the us spec TB have all those nipples??!
The jspec stock IC has 0 vaccum nipples as well. The top says "Turbo Rotary" as opposed to Turbo II. The IC inlet/oulets are a little larger as well as the entire IC being a little bit bigger.
The jspec's BAC valve adjust screw is on the end of the BAC.
Yes, no EGR valve.
Also there is no upper radiator hose fill cap on the jspec's.
Old Sep 9, 2002 | 01:11 PM
turboGXL's Avatar
ROFLMAO!
No, I think he meant that the fuel starts at the primary rail and returns via the secondary rail. I didn't realize that this was backwards from the US spec versions though.
Old Sep 9, 2002 | 01:35 PM
kllntyme's Avatar
Legend in my Spare Time
I think it's the position of the rails that is backwards.
Old Sep 9, 2002 | 08:25 PM
SLOWT2's Avatar
yes that is what i was talking about
