Insanely high fuel pressure!!
Old Sep 2, 2002 | 04:45 PM
Toddzilla's Avatar
Angry Insanely high fuel pressure!!
I think that I may have found the reason that my car has failed emission not once, not twice, but thrice. I actually decided to look at my guages and my fuel pressure is showing 95 psi ! Holy **** that high. I'm guessing that the cause is the fuel pressure regulator being stuck closed. Anyone know where I can get a new and/or adjustable FP regulator?
Old Sep 2, 2002 | 04:58 PM
Far North RX-7's Avatar
Is the car running when you have the high pressure or are you reading it when the engine is shut off.
Old Sep 2, 2002 | 04:59 PM
Toddzilla's Avatar
When it's running.
Old Sep 2, 2002 | 08:56 PM
Toddzilla's Avatar
What should the fuel pressure be anyways?
Old Sep 2, 2002 | 09:05 PM
DavidDeco's Avatar
I have more fun than you.
There's the Mazda 38 psi + 1/psi for each pound of boost rule.
My fuel system seems to beef that up a bit though. I'm not complaining now though having run rich and safe at up to 16 psi boost now a few times.
Old Sep 2, 2002 | 09:07 PM
Toddzilla's Avatar
Ok, thanks! So my car is TERRIBLY out of whack, I'm seeing 90 psi !!!
Please help!
Old Sep 2, 2002 | 09:21 PM
Toddzilla's Avatar
Another question, does the FD have a returnless fuels system or not?
I'm guessing that it does have a return line. If so, I'll call the dealer and see how much a fuel pressure regulator is.
Old Sep 2, 2002 | 09:22 PM
DavidDeco's Avatar
Please help!
Yeah, from what I understand you never want to be above 70 psi.
Old Sep 2, 2002 | 10:27 PM
Wargasm's Avatar
Weird Cat Man
Yeah that's a good guess that your regulator is broken or your return line is clogged or pinched. When you completely block flow, the stock pump has a bypass on it that triggers. This happens at around 100 PSI which fits with what you're seeing.
Did you have any work done on the car recently? Perhaps a shop guy lifed the car wrong and squashed a fuel line on the underbody and it's blocking the return?
B
Old Sep 2, 2002 | 10:30 PM
Wargasm's Avatar
Weird Cat Man
Oh yeah ... if it turns out your FPR is bad, I'd just replace it with another stock one. Your fuel pressure should be around 38 or so at 0 manifold pressure (disconnect the vacuum line or test with the engine not running).
B
Old Sep 2, 2002 | 10:37 PM
Toddzilla's Avatar
Thanks Wargasm...I did some work on the car recently, but I jacked it up from the engine cradle. What side of the car does the return line run down?
BTW - how much is a new fuel pressure regulator?
Old Sep 3, 2002 | 02:09 AM
duboisr's Avatar
Fuel lines are on the drivers side ,if you ever changed your oil or fuel filter you should know.
Old Sep 3, 2002 | 09:32 AM
Toddzilla's Avatar
Thanks, well I just bought the car a month ago and changed the oil once. I didn't pay attention to the fuel lines when I did it.
Any other ideas?
Old Sep 3, 2002 | 11:29 AM
loi's Avatar
loi
toddzilla, i think i saw your name on the corral a few time lol, welcome to the FD forums. btw how's the cobra running?
Old Sep 3, 2002 | 11:33 AM
Toddzilla's Avatar
Yup, that's me.
The cobra is running great....running low 13s on street tires and high 12s on drag radials. It is for sale though, I'm trying to cut my expenses and throw some money into the FD. That's why I bought the GT in my sig.
Old Sep 3, 2002 | 02:20 PM
Toddzilla's Avatar
HOLY ****! The dealer wants $1014 for a fuel pressure regulator. WTF?
Old Sep 3, 2002 | 02:26 PM
Mahjik's Avatar
Mr. Links
Is that parts and labor, or just the part?
Old Sep 3, 2002 | 02:30 PM
rotorbrain's Avatar
fart on a friends head!!!
dude just go ahead and get either the sx unit or the aeromotive unit. you can adjust it to what you want. im not sure what it should be as i need to ask that question (in relation to my mods) also. anyways, i would go ahead and get it if you are planning on beefing up your fd. i was told the stock fpr is only good up to about 15 psi. is this true?
paul
Old Sep 3, 2002 | 02:40 PM
Toddzilla's Avatar
Where can I buy the aeromotive FPR?
Old Sep 3, 2002 | 02:52 PM
loi's Avatar
loi
pm me, i can get you the aeromotive or the sx regulators. Any of your local mustangs show should have aermotive products. they are one of the biggest company that supply fuel system for the Renegade class.
Old Sep 3, 2002 | 03:53 PM
Mahjik's Avatar
Mr. Links
Arrow
http://66.216.67.51/subcatmfgprod.asp?0=211&1=262&2=-1
Old Sep 4, 2002 | 10:20 AM
Toddzilla's Avatar
Ok, just to summarize. It's either
1) The stock FPR is shot
2) My return line is crimped
Is that IT? Vacuum issues couldn't cause this?
Old Sep 4, 2002 | 11:03 AM
P'cola FD's Avatar
Hamado things my way!
I would get under the car, and look over all the fuel lines. They are on the driver's side, in the little protector tray under the car. If they all check out, what I would do next is to hook up your fuel pressure gauge and check the pressure with the car not running, but turned on. Take note of that pressure. Next, take off the UIM. Disconnect the return line coming off of the FPR. Put a hose on the FPR to aim the fuel that will be leaving into a bucket or something. Now turn the car on(but don't start it), and check the fuel pressure. If the pressure is the same as the first reading then it is probably your FPR. You may even see a lack of flow from the FPR. If the pressure returns to normal then you have a block/crimp somewhere in the return system. Make sure your gauge is reading right as well. I though I had fuel pressure problems before, but it turned out that my MAC gauge was reading about 10psi too high. If you need a stock FPR I have one that I'll sell for cheap.
--Danny
Old Sep 4, 2002 | 11:07 AM
Toddzilla's Avatar
--Danny
Thanks a lot for the procedure. I only have one question, what is the UIM?
Old Sep 4, 2002 | 11:18 AM
P'cola FD's Avatar
Sorry, it's the upper intake manifold. Once it is off the fuel lines are easily accessed.
BTW: Go Disco Stu!
