which rads fit s4 turbos
I cannot afford the high dollar rads (fluidyne,k2r ect.) but you can get decent alimubn radiator for other cars (GMs and such), aluminum ones, for like 150-200 buck. what other radiators have you guys seen used in s4 turbos with mild modifications for fit. So, aluminum radiatord that fit rx-7's that werent built for rx-7's but works sweet.
thanks dudes
jared
thanks dudes
jared
you can get the giffen ones. 22" by 18-19" is I think what they use for $200. you need to make your own mounts. and rig up some custom rad hoses.
but the rad won't have a spot for the heater hose, coolant level sensor, or the temp switch at the bottom...
do a seach for griffen rads you will get some pics
Search on Yahoo for radiators. Lots of places like www.radiator.com selling them ready to bolt in. Are they the best? probably not, but they are affordable. Should be no problem getting in the $140-170 range.
Check out www.absoluteradiators.com. Great prices on Fluidyne radiators. I have looked all around for a good replacement a just spent a few extra bucks on an aluminum radiator. Chris will hook you up!
immanuel__7
89
Sep 5, 2015 10:23 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
