Power FC O2 sensor voltage always reads 0.00v
Old Aug 27, 2002 | 04:25 AM
chrislloydus's Avatar
My O2 sensor always reads 0.00v....so i guess this means its bust ?
Doesnt actually seem to have any effect on my driving, which is weird. Tried cruising and part throttle driving which is where i thought the O2 sensor was used, but the car was fine.
I think i will turn O2 feedback off anyway, as others have reported that it improves the drive.
So is it bust ? and why doesnt it effect anything else ?
Chris
Old Aug 27, 2002 | 11:29 AM
.....just been out and checked an it is connected still. Wire is very taught though where it bends round the y pipe. Maybe the wire is bust.
No-one else had this problem ?
Does the PFC ignore the O2 sensor in part throttle ? Or is that what i would be turning off if i used the disable O2 sensor feedback option ?
Chris
Old Aug 27, 2002 | 12:26 PM
cewrx7r1's Avatar
Eye In The Sky
The PFC does monitor O2 voltage and does display it.
Get a high impedance volt meter and measure the voltage on both sides of the connector.
Old Sep 6, 2002 | 08:14 AM
sub-zero's Avatar
cewrx7r1, should the o2 reading on the PFC change in the sensor check area? My voltage is always 0.01 even though my 3 wire sensor conected to the Halmeter a/f is always changing. Did the guy who installed in not hook up the wire to the PFC, and would this cause misfiring on high load?
Thanks
Old Sep 6, 2002 | 03:41 PM
cewrx7r1's Avatar
Eye In The Sky
The PFC O2 reading should change just as it does at the sensor or AFR meter. Seems as if it is not connected to the PFC.
rgordon1979
40
Mar 15, 2022 12:04 PM
ZacMan
Sep 19, 2015 09:20 PM
mulcryant
Sep 9, 2015 05:24 PM
doritoloco
Sep 5, 2015 12:41 PM
