Springs Shocks and Struts
Old Aug 23, 2002 | 08:16 AM
Question Springs Shocks and Struts
Hello,
Have an 88 turbo and I wanted to know is there any bushings or anything I should change while I'm installing the springs,shocks,struts?
This is my first time doing it, it doesn't seem to hard to do......I just wanted to know is there anything special I should take into consideration?
Thanks,
Benny
Old Aug 23, 2002 | 12:59 PM
ARD T2's Avatar
You'll definitely want to replace your upper shock mounts that have the rubber bushing in it. I am sure the bushings are cracked over 14 years. This should save some time as you won't need to separate your stock strut and spring.
Let me know if you want us to get these for you. They are a factory part and am not sure how much they will cost.
Thanks, RIshie
Any of the other bushings would need to be done with a hydraulic press most likely.
Ernstudet22
Sep 14, 2015 09:19 PM
