upgaded Radiator not avail.??
Old Aug 22, 2002 | 11:28 AM
Question upgaded Radiator not avail.??
Does anyone know if anyone makes an aftermarket Radiator for a FD with an automatic tranny???
Old Aug 22, 2002 | 11:31 AM
GoRacer's Avatar
Speed Mach Go Go Go
PWR is the only one. You can get it from the rx7store but make sure you specify for "auto".
Old Aug 22, 2002 | 11:42 AM
I called the rx7store this morning and they told me they did not have one,, any ideas who else carries PWR??
Old Aug 22, 2002 | 01:25 PM
Rated R1's Avatar
Oji San
I know someone has it. I saw it the other day. It was special order though. I'll see if I can find it for you.
Old Aug 22, 2002 | 01:30 PM
What about using the a std. upgrade and then adding an aftermarket transmission cooler. does that sound like it could work.
Old Aug 22, 2002 | 03:36 PM
GoRacer's Avatar
Speed Mach Go Go Go
You can have Mazdatrix special order it for $100 more and two weeks.
You can try a mazdacomp because looking at PWR's website, it's possible they make them for Mazdacomp but not sure if MazdaComp carry's the auto version.
You can buy it from www "rotor motor sports" dot com
(can't post a link but best price of these four and most likely in stock)
or these guys
http://www.i-m-racing.com/pwralradrx79.html
For the other question: Auto's have a transmission cooler allready and it connects to the radiator. So there is only 2 choices: 1. Stock, 2. PWR
Old Aug 22, 2002 | 03:50 PM
GoRacer's Avatar
Speed Mach Go Go Go
Unhappy Oh wait, craps ("AWR")
Sorry, I mixed up brand names!
It's "AWR" and as far as I know, only www.Mazdatrix.com can special order it (unless rx7store knows where to get it from).
I think it's ok for me to post a price since they don't carry it in stock $590.00
Old Aug 22, 2002 | 10:31 PM
Awrracing.com is currently in the proccess of a production run of automatic radiators... 2 week delivery from order... $550.00 is the pricing on sale...My understang is this is the company that makes the radiator that MazdaComp sells... this puppy is 1.25" thick and is the same cooling as what a 3core rad would do....And...this is the only one i personally put my money on...and i have... ..hehe... awaiting mine now... good luck..Carter
Old Aug 22, 2002 | 10:35 PM
DK's Avatar
DK
40k worth of fail
You can use any aftermarket radiator on the auto. I haven't a clue why the tranny coolant runs through the stock radiator, but it doesn't provide any cooling to it by my discernment. You can just bypass it with a line and if you're paranoid there is room behind the stock cooler to pick up a $20-30 thin tranny cooler from an auto parts store and put it behind the stock cooler.
Old Aug 22, 2002 | 11:06 PM
GoRacer's Avatar
Speed Mach Go Go Go
Not exactly
Auto's have a Trany cooler in the same location as R2's 2nd oil cooler allready. Apparently, it's not enough so it also gets additonal cooling from the radiator.
PWR is the co that makes radiators for Mazdacomp (according to their website). Someone else memtioned they make them for M2 also, but I don't know if that's true.
AWR is a different company and Mazdatrix is the only place I know of that sells them and they are the only brand I know of that makes i=one for autos.
Old Aug 22, 2002 | 11:55 PM
DK's Avatar
DK
40k worth of fail
Re: Not exactly
Yes, I know there is an auto tranny cooler in front of the passenger front wheel, and that's why I said to stick an additional thin aftermarket one in behind it because I have done it before and therefore I know that it can be done.
I don't, however, believe that there is a cooling capability provided by the stock radiator to the tranny fluid passing through it. I haven't taken an auto radiator apart to see what the differences are, but it looks to me like it only passes through the base and not through the fins, therefore providing very little, if any temperature drop (and it might even raise temps?). I could be wrong, but I almost think the tranny line passes through the base of the radiator out of convenience.
Old Aug 23, 2002 | 12:18 AM
Jason's Avatar
The one
I will make a call to PWR tomorrow and see it they have any for the auto. I was under the impression they didnt and appologize for any wrong info I may have given. Feel free to send me an email tomorrow and I will get more info for you.
jbaughman@columbus.rr.com
Thanks
Jason
www.rx7store.net
Old Aug 23, 2002 | 12:34 AM
GoRacer's Avatar
Speed Mach Go Go Go
Oh sorry DK.
Jason, the Company that sells the radiator for the Auto is ("A"WR) AWR. There is another brand that you allready carry ("P"WR) PWR.
Mazdatrix carries the AWR, but i'm not sure if they will tell you their source. Maybe you can just ask what the initials stand for and what country then search for it.
Old Aug 23, 2002 | 06:17 AM
Thanks for all the info. guys. I am still trying to decide which way to go. I have been thinking about a std. aftermarket rad. & then putting an aftermarket tranny cooler with a fan on it right behind my fmic. I think this would provide enough cooling for the tranny plus the one I was looking at pulls 1200cfm. This might also help pull more air thru the intercooler. What do you think??
Thanks
MidnightOwl
Sep 25, 2015 10:24 PM
