little problem w/ door handle
Old Aug 21, 2002 | 12:56 PM
DaPlaya96's Avatar
my passenger door handle thingy is loose
shakes a little like its starting to come off
but still works
why is this so?
how can i fix this?
what should i do?
Old Aug 21, 2002 | 12:59 PM
JUSTgotMINE's Avatar
You can prbably replace the part...try mazdaformance
Old Aug 21, 2002 | 01:05 PM
DaPlaya96's Avatar
cant i do something about it instead of replacing it?
Old Aug 21, 2002 | 01:24 PM
Jim Calandrella's Avatar
The Ricer Eliminator
Try this. On the inside of the door(behind the door handle), there is a plastic cover. Take that cover off. It should just pop off. There will be two screws in there. Try tightening them. There is a good chance that that's your problem.
Jim
Old Aug 21, 2002 | 01:34 PM
neo_omega's Avatar
***Moderator***
Re: little problem w/ door handle
but still works
why is this so?
how can i fix this?
what should i do?
which part? there are a lot of parts on the handle thingy.
Download the shop manual. It should help you. At least you can let us know which thingy you taking about.
http://www.iluvmyrx7.com/3rd_gen_manuals.htm
Old Aug 21, 2002 | 04:15 PM
DaPlaya96's Avatar
the outermost cover.. the part which is very easy to scratch up
