HELP! GSL-SE high RPM stumble
Old Aug 13, 2002 | 02:40 PM
killjoy7's Avatar
Exclamation HELP! GSL-SE high RPM stumble
My 85 GSL-SE has developed a high rpm stumble. As I accellerate and get near redline, the engine misses and stumbles until past redline. It happens between 6-8k rpm and is not a huge miss but definately noticeable. Only happens under load. Revs fine while in neutral. Fuel pump and filter are recently replaced (6 months ago) as well as fuel pressure regulator.
This is on a stock EFI 13B with only mod being Racing Beat roadracing header and exhaust.
Any Ideas?
Old Aug 13, 2002 | 03:12 PM
diabolical1's Avatar
cap -n- rotor good?
ignition wires arcing/arching (sp?)?
timing within spec?
are the injectors clean?
are all six ports opening?
sorry can't think of anything else right now, but by the time you check these things, maybe someone will have some better, more helpful, ideas.
peace
Old Aug 13, 2002 | 04:16 PM
Directfreak's Avatar
I am a Jeeper Now.
Timing / Plugs / Wires / Coils
In that order.
rgordon1979
40
Mar 15, 2022 12:04 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
The1Sun
Sep 15, 2015 04:45 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
The1Sun
Sep 7, 2015 10:21 PM
