View Poll Results: If money where not an issue, which would you rather have?
Turbocharger
83
63.85%
Supercharger
47
36.15%
Voters: 130. You may not vote on this poll
Turbo or Supercharger??
Old May 24, 2002 | 04:27 AM
Project84's Avatar
Open up! Search Warrant!
I don't know if I want to spend 2 grand for an Atkins rotary 13B turbo for my 1st gen, or if I want to save some more dough and get a street ported 12A w/3mm seals and a camden supercharger. This is what brought about the question in my poll.
Old May 24, 2002 | 05:45 AM
MikeLMR's Avatar
'Last Minute' Rallying
watch Mad Max then buy a super charger ... sorted
Old May 24, 2002 | 07:35 AM
Sterling's Avatar
Nikki-Modder Rex-Rodder
I love superchargers. Unfortunately, the Camden is not the greatest SC. I think there are other options for the 13B.
Old May 24, 2002 | 09:16 AM
yayarx7's Avatar
Are you Nucking Futs?
I would go with the turbo, as it is easier and has been done so much there is a ton of support out there, on that note, the SC would be different, if you are into that.
Old May 24, 2002 | 09:31 AM
BadAssRX-7's Avatar
The AUTO DOCTOR
hte turbo is cheaper and will make more safe power... ane like yaya said theres more suport out ther for a turbo. and FYI a 12a has 3mm seals STOCK
Old May 24, 2002 | 09:41 AM
RXcetera's Avatar
EliteHardcoreCannuckSquad
How about getting a ported 13B, a big carb and forgetting all about turbos and SCs... just a thought...
Old May 24, 2002 | 09:49 AM
1st7heaven's Avatar
I had alot of fast, fun, and most important RELIABLE,
years on a 4port, 13b, Holley, and header motor. It wasnt as much hp as a turbo or supercharged motor but the motor lasted almost 7 hard years! You can out run any normally aspirated imports and most stock V-8s. Most important, under $2000.00 for new parts!
Old May 24, 2002 | 10:08 AM
RXcetera's Avatar
Could you imagine a streetport or even a bridgeport on your 4 port 13B setup? You'd be looking at more than 250 reliable hp .
Old May 24, 2002 | 10:17 AM
1st7heaven's Avatar
Amen! I had a bridge ported 4 port in a race car(autocrosser). I cant imagine it on the street!!
I am building a new motor right now for autocrossing, lightened and balanced 89' rotors and shaft, hardened and locked gears, 93 oil pump, bridge ported, 48 webber, electric water pump, header into 3", Dynomax. Combined with my 1900lbs.............YEEEEEHHHAAAAA!
http://members.cardomain.com/7heaven
Old May 24, 2002 | 01:03 PM
mar3's Avatar
Administrator
If money were no object, I'd run a turbo for each rotor, intercooled, water-injected and nitrous'd for good measure...
Old May 24, 2002 | 04:10 PM
RXcetera's Avatar
Omg, how many times is this thread going to go back to the top without anyone posting anything?? I hafta put a stop to this...
Old May 24, 2002 | 04:13 PM
1st7heaven's Avatar
we need to add "normally aspirated" to that pole hehehe
Old May 24, 2002 | 04:14 PM
mar3's Avatar
Administrator
Ha Ha!! Here it is again, at the top!! People are voting on the poll but not posting like the rude animals they have become...silently sneaking in the background...
Old May 24, 2002 | 04:55 PM
Defprun's Avatar
Punk Ass Bitch
I'm going to turbocharge my car until i run out of money, i will upgrade this turbo every couple of years, and lighten and harden the internals until i cannot anymore, and when i cannot..ill stuff a 20b in there, at wich point i will turbocharge the crap out of. The 12a that was in there, i will transplant into another car, not sure yet what kind...cavalier? LOL
Old May 25, 2002 | 03:00 AM
Kill No Cone's Avatar
I have seen the Atkins turbo of a 76 cosmo at the Import drags and I was not impressed. I also understand that the belt stress the front seal or bearing and you need to modify the front housing to make it last. I would just build a nicely ported engine.
Old May 25, 2002 | 02:28 PM
mar3's Avatar
Administrator
The stress at the crank will also be present for any SC applications, which is another thing to worry about....
Old May 25, 2002 | 04:53 PM
REVHED's Avatar
Hunting Skylines
The power available from forced induction is great but for me you can't go past the simplicity of a ported n/a engine with a good carb.(weber,dellorto)
Plus, nothing beats the sound of an IDA Weber at full throttle on a ported engine.
Old May 25, 2002 | 06:58 PM
Directfreak's Avatar
I am a Jeeper Now.
Agreed.
Except the PHOOOOSH!!!! of a 13B Turbo's Blow Off Valve as it fly's by under boost..
Old May 25, 2002 | 08:19 PM
stinkfist's Avatar
Learn to swim.
Q: Whats the difference between a 250hp N/a and a 250 hp turbo motor.
A: about 60 ft/lbs of torque
Old May 25, 2002 | 08:33 PM
Defprun's Avatar
Punk Ass Bitch
Superchargers just suck. Suck power from your engine!!
Old May 26, 2002 | 01:01 AM
Project84's Avatar
They put in more power than it takes to run it, or it wouldn't be any more than dead weight. As far as the stress on the front seal, bearing, and mods to the housing, I wasn't aware of that. Thanks for the input. I think I will more seriously consider turbo rather than a supercharger.
Old May 26, 2002 | 03:07 AM
madaz07's Avatar
Pew Pew Pew
hey revhed are they your real mags, looks good
A supercharged engine will be bitch to keep quite if you want max hp. the turbo 13b IMO is a far better optoin they can be kept pretty quite without losing too much hp and will probably be cheaper in the long run when you have to rebuild them
Old May 26, 2002 | 06:58 AM
REVHED's Avatar
Hunting Skylines
Nah, photoshop. Did you go to Willowbank today for Drag Combat?
Old May 26, 2002 | 07:08 AM
Sterling's Avatar
Eh-Eh-Eh...Don't get me ****** started, fellas!
Know yer **** before ya talk it.
Old May 26, 2002 | 07:27 AM
ASEmaster's Avatar
I would vote supercharger.. I had no idea there was one available for an FB. You get none of the lag from a turbo, you don't have to mess with the exhaust system to the extent you would with a turbo either. You probably wouldn't need to baby it like you would a turbo for it's longevity either (proper warmup/cooldown procedures). As far as stress on the crank goes, it wouldn't think it would be that adverse if done correctly.. if it took the place of your airpump, it would probably be NO different to the shaft.
Mad Max did have a sweet SC, but I've never seen one you could turn on and off like that How would the air get into the motor when it was turned off?
I don't have the $$$$ for any type of charged air system, so it's all academic at this point anyhow (maybe I could modify my smog pump to add some boost ), but there's my 2 cents!
