Tricky Timing Test !!
Old Aug 9, 2002 | 04:08 AM
Lemme ask this one to the Guru's of Timing ..I seemed to stump a few people on this one, hoping someone in here may have come across this one before.
Sayyyy... you re-build your FD engine and use 2nd Gen housings (cheaper) but the distance between the leading and trailing plugs are different to that of the leading and trailing plugs on an FD housing ... what timing do you use ????
..FD timing or FC timing ?!?!? or some where in between the both ???
What is standard FD timing and FC timing anyways ??
TIA,
3G7
efini7
Test Area 51
Sep 4, 2015 02:59 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
