abs light after brake job
Old Aug 2, 2002 | 01:13 AM
suprfast's Avatar
okay, the ABS light is on. turns on five seconds after i start rolling. here is what i did. changed the pads out for hp+. went with stainless steel brakelines all the way around. beld the system twice to insure that there was not any air. used valvoline synthetic brake fluid. bled it till it came out clear, starting from the rear passanger, rear driver, front passanger, front driver(furthest to closest from master cylinder). also turned the rotors. saw metal flakes on the ABS pin that meets to the half shaft and cleaned them off. can anyone lead me to a solution that can fix this problem. i am stumped. checked all my fuses and they seem fine. have not checked the relays yet. please help someone.
kris
Old Aug 2, 2002 | 02:34 AM
darkside7's Avatar
ck ur brake fluid level
fastsaab
Aug 19, 2015 11:42 AM
