Vaccum Tube help
Vaccum Tube help
On the side of the dynamic chamber there are 3 vaccum tubes. where does the bottom hose get connected? i had a little problem finding where it goes. thanks.
bottom blue hose on the side of the chamber http://www.agsrhichome.bnl.gov/Peopl...tb_removed.jpg
Toooooo, toooooo easy if you mean the three blue vacuum hose on the front of the dymanic chamber. The bottom one is the only one that is pulling a vacuum from the throttle body, and it goes to a metal pipe sticking straight up below the alternator. That hose feeds a vacuum to most of the solenoids on the left side of the car.
Big top hose: to the oil injector spider and feeds fresh filtered air to the oil injectors.
One below the Big top hose: to the metal nipple b/t the oil injectors on the intake manifold. Feeds fresh filtered air to the fuel injector bleeds.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
