help!!! hks F-CON....
Old Jul 30, 2002 | 04:20 PM
peoples's Avatar
Angry help!!! hks F-CON....
Hks must think i can read japanese, but i cant.
i need help hookin up the fuel cut and the pressure sensor.
im not sure which color wires from the pressure sensor go where??? in the wiring harness.
it would be the most help if i had english instructions.
any help would be great..
Old Jul 30, 2002 | 04:47 PM
Greg's Avatar
even the wiring diagram is in jap?
Old Jul 30, 2002 | 07:10 PM
Ranzo's Avatar
Post the instructions and then I can help you.
Old Jul 30, 2002 | 07:24 PM
Dustin Setayesh's Avatar
hope this helps
______________
[ ][ ][ ][ ][P][ ][ ][ ]
If you have a series 5 then the 16 pin connector will have the pressure wire.
________________
[ ][ ][ ][ ][ ][ ][ ][ ][P]
If you have a series 4 the pressure wire will be on the 18 pin connector
hook up th FCD white wire to the wire going to the Factory sensor and the yellow FCD wire to the ECU.
Make sure to turn the FCD 7 clicks from the cut side.
The red and black wire are +12v and ground respectively. I am not sure if you need where the HKS pressure sensor wires go but here:
On th F-Con harness
_________ _________
[ ][ ][ ][B][Y] [ ][ ][ ][ ][ ]
[ ][ ][ ][G][ ][ ][ ][ ][ ][ ][ ]
B - blue
G - green
Y - yellow
Old Jul 30, 2002 | 07:25 PM
sorry it did not show like I typed it. I hope this helps.
Dustin
