t2 conversion
Old Jul 27, 2002 | 01:34 PM
suprfast7's Avatar
Talking t2 conversion
Alright i am planning on converting my 87 GXL tranny to a t2 will i need the diff and halfshafts, isnt the GXL and t2 diff and halfshafts the same.
What will i need to do this i can get a tran, driveshaft, flywheel, and clutch p plate. is this all i need.
Old Jul 27, 2002 | 02:37 PM
dre_2ooo's Avatar
1/2 shafts are not same
you will need all that and more.
-ECU
-Turbo
-Boost Guage
-Rims/Tires
-Differential
-Suspension (for the true TII feel)
-Intercooler
-Hood
-Fuel Injectors
-Fuel pump
-TII Decals
Sure you still wanna do thiis? ($$$)
Old Jul 27, 2002 | 03:14 PM
bcty's Avatar
Boost This!
he is just doing the turbo tranny!! u need the tranny and i think the cluth and flywheel.. and your good to go not to sure about the driveshaft
Old Jul 27, 2002 | 03:27 PM
suprfast7's Avatar
just the transmission not the whole t2 conversion i might as well just buy a t2. but will the GXL drive shaft fit the t2 transmission?
Old Jul 27, 2002 | 06:34 PM
darkwaveboi's Avatar
Need donor car in Fairfax
you can get a driveshaft shop to fab you a custom driveshaft that mates w/ the N/A diff.
Remember: the TII diff isnt just stronger, its also LSD...better turning + better traction.
Old Jul 27, 2002 | 06:35 PM
no, the splines are different. I have both, the TII driveshaft also has a sheild over the yoke
Old Jul 27, 2002 | 06:41 PM
suprfast7's Avatar
so i need the trans and flywheel clucth and driveshaft but i can get everything later. where are the halfshafts located and how hard are they to replace.
Old Jul 27, 2002 | 06:57 PM
banzaitoyota's Avatar
What Subscription?
Its MUCH easier just to buy the TII subframe and replace everything all at once!!
Old Jul 27, 2002 | 10:09 PM
jspecracer7's Avatar
1JZ powered
I think it would be much easier just buying a TII.
Old Jul 27, 2002 | 10:28 PM
yeah, but enless your able to pick up the subframe, isnt it huge?
Old Jul 27, 2002 | 10:38 PM
suprfast7's Avatar
so i am just going to buy the trans clutch flywheel and driveshaft and get it fab so it will fit? I dont have the money for a t2unless its dirt cheap
and shipping for a sub frame or finding it around here is impossible.
Old Jul 27, 2002 | 11:53 PM
Evil Aviator's Avatar
Rotorhead
Plus all the TII components are more weight = slower car, not to mention more expensive. Unless you have more than 200hp, I would recommend sticking with the NA components. If you do need the heavier TII components, then I recommend buying an entire TII with a blown engine and changing everything out - rear subframe, front suspension, transmission, driveshaft, clutch & slave cylinder, etc. If you are a good salesman, you can even sell the remaining components (TII hood, spoiler, old NA parts, etc.) for what you paid for the TII.
Coochas
44
Nov 5, 2019 11:08 PM
