S4 and S5 doors
Old Jan 8, 2009 | 02:11 AM
red_dragon's Avatar
S4 and S5 doors
Are the door shells the same for S4 and S5? Someone hit my TII in a parking lot and made a huge ugly dent in it. Fortunately most parts inside still look ok, so I'm just trying to make sure S4 and S5 shells are the same. Thanks!
Old Jan 8, 2009 | 02:45 AM
katkaroto's Avatar
dewey
should be the same, just make sure you replace the door with one that matches your car. some 7's have side moldings and some dont. dont ricer it up.
Old Jan 8, 2009 | 02:53 AM
red_dragon's Avatar
yea thanks for the tip. Do you know which ones do and which ones don't? And by moldings do you mean the plastic piece on the door or is that something else? I know there's a black trim on S4s, but the trim on my S5 is still good, so can it be swapped?
Old Jan 8, 2009 | 11:10 AM
Mr.FC3s's Avatar
Rotard
I think the S5 had plastic trim and the S4 has the rubber ****. I think they are both the same physically but I dont know about the moldings. just see if you can swap moldings and then transfer the door over.
Old Jan 8, 2009 | 06:51 PM
katkaroto's Avatar
dewey
moldings, trims... something like that... anywho.. so far i noticed my 87 TII has the trims and my 88 GTU sporty doesnt... also... i've seen S4 verts with trims, those were found at the junk yards... well good luck
Old Jan 8, 2009 | 06:57 PM
need RX7's Avatar
Listen to King Diamond.
The moldings will swap over, and the doors will be the same.
powerhousefd3s
Oct 13, 2015 01:54 PM
