it looks good. most of those rust spots wont be too hard to fix. does it run? u used carb cleaner to clean my engine bay ( its about that time again ) just make sure to rinse it off and cover your dist., alt, and carb when you do it and make sure to not get water in those parts as it makes starting it a bitch until they dry out. i like the tar idea i have some rust sealant that goes on in a coffee and creme color and is black when it dries, and im going to be doing the same thing here in a few weeks.
1982 S 12a 153k+miles and running strong 2gcdfis, CA emissions intact, 1 1/8 inch front swaybar, cold air intake mod for carby, big bearing rear end and driveshaft swap, rear sway bar, header panel scoop
