project: paint the 7
Old Jul 1, 2004 | 06:31 AM
  #101
sosofast's Avatar
Originally posted by WonkoTheSane
apreludem You can't sand when the paint is tacky.. I can see where you got confused, there's a few terms that can be used interchangeably (is that word?), like layers and coats and such... the paint process should go like this for every coat (stage of paint, i.e., primer, basecoat, clearcoat):
After doing all of your prep on the old material, wet sand and clean off. Spray down a thin layer of primer, wait until it is tacky, spray another layer down, and repeat. normally you don't need more than two or three, but primer is where you fix your mistakes.
Wet sand the primer with about 1000, get it as smooth as possible, use a glazing putty (It's a thin body putty, much thinner than regular putty), and wet sand that smooth. Take your time, be sure to putty any sanding marks that the wet sand can't take care of. wet sand the glazing putty. Wash the car off. The putty surface should now be pretty smooth (you'll never get primer as smooth/reflective as normal base/clear coat.
Spray down the first layer of basecoat, go slow, put it down thin, be sure to get even coverage, and when it's tacky, spray down some more. keep going until you reach your desired thickness/coverage. I know on my car I went a little heavy with my basecoat, so it only took about 5 times over each area to give me a nice, deep looking black color.
After it dries, (I let it sit a day), wet sand the car again, using 1200 grit sandpaper. This is your only chance to get out runs on the base coat, so be very careful and try to flush them out as best as possible. respray an area if nessisary. be sure to wetsand and clean up again if you have to respray.
After the basecoat has been sanded and dried (I waited a day), spray down the clearcoat. take this Slowly, the thinner the better. keep going until you have nice, even coverage all over your car. I think I have about 6 layers on my car thick layers on the "just black" areas. I ran out of clear, but I think I have enough, on mine.
Now you just have to let all the paint dry for a few days before you take it out, and remember to NOT USE ANY WAX for about 2-3 months on it. Your paint will still be drying after this time, even though it solidifed two months ago.
I am just getting ready to do the first canuba wax on my car (painting finished ~3 months ago), I'm going to now sand the car with 1400 Grit wet sand paper, then dry it, then canuba wax it two to three times.
I think that's a pretty good summary of the painting process, anyone care to critique?
i read somewhere that sanding the basecoat will make it shiny like sanding metal. and it was a bad thing, especially for metallic paints. the clearcoat is supposed to make it shiny
i've been reading alot of stuff about painting, and the more i read the more i get confused. Your way seems to make sense, so i might do it your way.
Old Jul 1, 2004 | 07:28 AM
  #102
WonkoTheSane's Avatar
Green Flameless
SoSoFast Wetsanding with 1000 will definatly not give you a glossy basecoat.. you will be able to see (not feel, though), microsanding marks on the basecoat after you sand it.. I think I was using 900 or 1000 wet sand on it, and it still looked like it was sanded. It is sorta glossy after you lay it down, though. For examples of this, take a look at my "unsorted and unresized pictures of my rx7 paintjob". it's at http://www.killermonks.com/rx7 . The directories that will be of interest to you will be "firstbasecoat" and then "green". In the Firstbasecoat directory, you can see how it looks sorta glossy (not like after I spray the clearcoat on it, but shiney), then if you look in the "green", especially the sunroof and doors pics, you can really see the sanding marks around where the green metalflaked clearcoat is..
Hope this helps!
Old Jul 1, 2004 | 04:18 PM
  #103
mycarisolderthanme's Avatar
Back.
why isnt this archived yet?
Old Jul 1, 2004 | 07:23 PM
  #104
Green Flameless
I think archiving would be a good idea, I've seen enough people reference this in other threads
On a unrelated note, I finally got on my duff, and resized all of the in-progress images the link above, and named all the pictures.. I recommend you take a look at "green" and then look at the sunroof pictures to see what I'mt alking about with the sanding marks, then go into the clearcoat one and look at the sunroof again
Old Jul 2, 2004 | 03:57 PM
  #105
eyeoutthere's Avatar
Awesome info! This will definitely come in handy.
Old Jul 3, 2004 | 03:51 AM
  #106
sosofast's Avatar
Hi i just received my hvlp gravity feed spray gun. But i oredered the one with the 2mm tip cos i read it sprays acrylic better. But they send me the 1.7mm tip one instead. Should i exchange it. Or wont' it make a difference with the paint?
thanks
Old Jul 3, 2004 | 08:08 PM
  #107
Green Flameless
NOTE OF WARNING: Do NOT follow the directions i received and wet sand the clearcoat right before you wax... I just did this today, and I'm having a helluva time getting the shine back... I'm not sure what my problem is, but it's acting like the wax is simply not coming off. I'm thinking that it may be the 96% humidity here today (hey, it was nice in the morning), and it's not allowing to the wax to dry. Either way, I'd avoid that for now, and maybe go with a polishing buffer or something to get rid of minor surface clearcoat orangepeel (which is what I was trying to get rid of).
If I can't get it to become shiney tomorrow, then I'm going to just wet-sand off the wax and respray some more clearcoat on monday. You can never have enough clearcoat
Just for the record, i was using McGuire's (sp?) #26 or 7 wax...
sosofast I'm honestly not sure how the different tips will respond.. The gun I was using is 1.4mm, and that seemed like plenty of flow to me.. That's a good question though, Any body shop guys in the house?
Old Jul 24, 2004 | 10:58 PM
  #108
crickifur's Avatar
Good luck man! I am getting ready to paint my FC myself... I am in the army though and have use of a COMPLETE auto garage including a down draft paint booth and all the tools needed. Even with all that though, I am still scared I am going to mess it up.... I have a lot of fiberglass to work on too though so who knows.....
Old Aug 21, 2004 | 05:27 PM
  #109
aka_rocket's Avatar
7s bein a pain in the ass
awesome information here...my car's paint is starting to bubble and drip and (looks bad up close) yea...the previous owner just painted right over the old stuff, i don't think there was any prep work at all so its all weird looking now. good thing this info is here, definitely VERY informative.
Old Aug 22, 2004 | 12:00 AM
  #110
Green Flameless
sosofast & crickifur- How did your car ever turn out? c'mon, I wanna see some pics.
aka-rocket - Good luck, as long as the body is in good shape, a recoat shouldn't be TOO hard I just shot a friend's prelude last week, and that's pretty much all we did. Took less than a week and a half from start to finish.
UPDATE ON MINE - I guess I never did finish explaining what was happening with mine at the buffing stage. As I suspected before, I did need to use a polishing compound instead of just the straight wax, however, I realized that the clearcoat was a little thinner than I wanted it to be, so I re-sanded, and dumped another gallon of clearcoat on it. that was about a month and a half ago..
NOw I'm equipped with a 20 dollar wal-mart buffer, some polishing wax, and some fine grit sandpaper.. This time it will be REALLY shiney. Probably next weekend or the weekend after.
Old Aug 22, 2004 | 02:09 AM
  #111
andrew lohaus's Avatar
well its been more than a month since ive done my paint job so i thought id post back.
the one thing i can realy emphasis in hind site is the importance of waiting about 10-15 minutes between coats of base or clear. this "flash time" allows the paint to set up and begin drying before the next coat comes down. if you dont do this the paint will "sag" as it dries even if it doesnt look that way right after spraying. so just spray a few light passes (think more of "dusting" with the paint then "coating') then wait before repeating. in other words, if you are spraying so much that you can see sags while its wet, you pilled on FAR to much paint. it might be too much, too fast even if it doesnt look saggy while wet.
also wait a week before wet sanding the clear for the final time. want it to be COMPLETELY dry before that last sanding.
-andy
Old Aug 22, 2004 | 10:02 AM
  #112
Green Flameless
Good call on the clearcoating tips. A lot of people get crazy after the first coat they slap down (since it has such a nice surface to adhere to), and put the same thickness on next time, then it runs...
Personally, i'm waiting until right before I polish and wax to sand the paint. but to each their own As long as you use 1500 grit for the final finish
Old Apr 10, 2005 | 09:50 PM
  #113
derek1987's Avatar
RX7 FOR LIFE! **D
great info.
WonkoTheSane, what type primer did you use? What do you recommend?
what brand base and clear did you use?
Old Apr 10, 2005 | 11:55 PM
  #114
staticguitar313's Avatar
R.I.P. Icemark
Really smart tips on Finishing in this thread, thank gos people know how to lay down good finish
Old Apr 11, 2005 | 08:55 AM
  #115
Green Flameless
Originally Posted by derek1987
great info.
Wow, this thread is back from the dead!
I don't remember the exact brand of primer I used. I let the guy selling me the paint worry about that. It was a primer-sealer, though, I can tell you that. I used a Tran-Star clear coat, which worked out well. I really wanted to go all PPG, but I didn't want to pay for it for my first attempt at doing bodywork/painting. I'll probably end up doing that next time, but for this time, the cheaper brands worked out. I think the trick is to go around to some good paint stores, and see what combination they suggest.. They work with that stuff all day long, they'll know what works and what doesn't.
Old Jun 13, 2005 | 09:54 PM
  #116
derek1987's Avatar
RX7 FOR LIFE! **D
Question for you guy who have paint your own car. Should I go with a single-stage or a base/clear system. I look for a decent shine and durable enough to handle everyday driving.
Please gave me your opinions?
Thanks guy, you are the greatest group
Old Jun 13, 2005 | 10:28 PM
  #117
Green Flameless
Wow Derek, you really keep this thread alive
There is no way you could convince me to go with a single stage setup, especially after the polsih I just did on the car The more clearcoat, the better.
Old Jun 13, 2005 | 11:43 PM
  #118
trochoid's Avatar
Old Fart Young at Heart
If you want that look of depth in the paint or any kind of a 'wet' look in the shine, go base/clear. Single stage looks good on tractors and lawnmowers, or those who are going for a flatter look, like the old ratrod style.
If you are using any king of metallic or pearl, you need the clear for protection and depth.
I don't agree with 'the more clear the better' mantra. Too thick of a clear and the layers of the clear won't dry properly and will crack or 'alligator' over time. This is for the polyurethane clears, which most automotive paints are now days. Back when laquer was prevelant, more was better.
Old Jun 14, 2005 | 12:06 AM
  #119
WAYNE88N/A's Avatar
Time for my 2 cents, lol...
I've been trying to perfect rattle can paint (Rustoleum) jobs on scrap pieces of aircraft skin panels for some time now. I still don't know if I'm going the "ghetto" way with the rattle can, or if I'm going to splurge for a "professional" paint job, but I have somewhat perfected the rattle can primer, paint and clear coat.
Micro-mesh makes a sanding kit for acrylic and lexan aircraft windows (we gotta get the scratches off or the passengers freak, lol), and it works wonders on clear coat paints for the wet sanding steps. I got a coat of clear to literally look like water by using the micro-mesh kit ($35, BTW).
You start with 1500 grit, then work your way up to 6000 grit using their "floating" pad behind the sanding cloths, then polish it to a sheen.
I'm waiting a couple of months to see how the Rustoleum clear coat stands up to the Houston sun (I practiced on the sunroof, it was rusting to hell anyway). I will not use the rattle can approach if it doesn't, but so far (about 3 weeks) it's doing OK.
The main problem with rattle can, as I see it, is the freakin' tiny spray pattern...
I'm assuming that it won't be as hard as the polyurethane systems either...
BTW, like trochoid said, you don't want TOO many clear coats...
Old Jun 14, 2005 | 12:15 AM
  #120
revhi's Avatar
I just finished painting my car protege blue I spent more time fixing dents and rust than painting. Not quite done with the car but done painting. Heres a pic
Old Jun 14, 2005 | 02:21 AM
  #121
jono20's Avatar
itts alll about the bondo baby
Old Jun 14, 2005 | 10:30 AM
  #122
derek1987's Avatar
RX7 FOR LIFE! **D
Damn nice work!
That is about what color I want. What paint code is that?
I think I want to paint mine 2003 color off the maita. 24A... i believe
Old Jun 14, 2005 | 10:38 AM
  #123
Green Flameless
Wayne, it wouldn't be the same without your two cents Any chance I can get ahold of this Micro-Mesh stuff? I definatly want to try it.
Just for clarificiation: When I said the more clear, the better; I didn't mean to just and throw as much clear on as possible. Just that you don't have to be timid with it. I've seen professional hot rodders talk about doing up to 6-8 coats, but taht's if you mist it. If you glop it on, only do maybe 4. My car as 6 coats in a few places, as anywhere the green is has clearcoat with green metalflake, then there's 3 coats over the entire car.
