peter farell intercooler is it a good setup?
Old Jul 30, 2004 | 03:55 PM
  #51
ech's Avatar
ech
PFS is great for a modified street car with stock turbos. Track cars and bigger turbos can benefit from a larger IC, but for tooling around town with 725-300 rwhp pfs does just fine. A larger IC won't prevent heat soak.
I have a 8"fan on my PFS IC - but no vented hood. Ive taken core temps on the IC, and the fan doesn't prevent heat soak, but it does slow it down a little bit and speeds up recovery a little bit. It also prevents the underhood temps from going through the roof when you park the car on a hot day after city driving . (well it does if you hook it up to run off a thermostat after you shut the car off). I figure this is good for preventing the hoses from going brittle and all that. If I was going to do it again I'd go for a 10 fan and make it fit. The 8" is a little weak and sounds like a hairdryer.
Old Dec 6, 2004 | 09:28 AM
  #52
M104-AMG's Avatar
I saw an ARC intercooler that fit's into the stock location with the stock airbox and stock battery.
How does it compare ?
:-) neil
Old Dec 6, 2004 | 05:07 PM
  #53
SPOautos's Avatar
Hey, where did my $$$ go?
Just get what ever you can afford. I think you can tell from this thread what is most desirable. Get the best IC you can afford. If you buy it used you can always sell it later for the same price and get your money badk to go with something else.
Stephen
Old Dec 9, 2004 | 05:15 AM
  #54
fstncln's Avatar
Fstncln
Comments on Greddy/Trust?
Lots of talk about the PFS, APS & M2 unit but not much on the Greddy/Trust unit. Is there a reason for this? Are they just that rare or are they not even good enough to be considered? My car had one on it when I bought it. I've got the ducting taken care of and still use the stock battery box (for the cooling) with a smaller battery. I can see the lower entry isn't that great but the core seems pretty thick so it shouldn't be too bad as far as pressure drop, am I wrong? I've got a Pettit intake, hard pipes, efini Y and upgraded turbos as well as a Bonez DP/high flow cat and Greddy cat back. Bottom line: I'm getting the air in and out pretty well elsewhere but I'm concerned the Greddy SMIC may now be the restriction. With so many comments about running the PFS, etc., at 15 psi I'm wondering if I need to upgrade or not. Sure, I'd like the v mount too but it is pricey and I don't know if it will really make that much of a difference or not. Anybody care to comment on the Greddy?
Old Dec 18, 2004 | 05:16 AM
  #55
Black97VR4's Avatar
FEARED
I think the GReddy is just a metal version of the OEM. I could be wrong and its the Blitz though.
BTW, I might have a PFS SMIC for sale soon when I get the car back from KDR. Reason for selling is the fact I went single and needed a FMIC.
Old Dec 18, 2004 | 05:37 PM
  #56
Tim Benton's Avatar
FD title holder since 94
The greddy is a bit larger than stock, but not as large as the PFS. Go with what Stephen said, get what you can afford and it will be better than stock.
Tim
Old Jan 12, 2005 | 09:58 AM
  #57
Riccardo's Avatar
I have the following setup
PFS IC
M2 CAI
SR Radiator
I just love the PFS, only downside, which I have corrected with the M2 CAI is the air robbing between IC and Intake as like stock setup they source air from the same duct
Old Jan 13, 2005 | 07:31 AM
  #58
Howard Coleman's Avatar
Racing Rotary Since 1983
a pretty good thread re ICs..
i don't have much to add except my friend has had a PFS IC since 1994 and has tracked his car aggressively and i can tell you the IC has done an excellent job. 15 psi, 165 mph on race gas and no motor problems. nice, compact with excellently shaped endtanks and tube design.
i agree w Kevin "T" Wyum, as usual, that it just comes down to your budget. if you can snag a good condition used PFS w duct for around 5-600 and it would help your budget you will absolutely never regret it. it is an excellent piece.
if you have a larger budget go for the ASP medium. i run the ASP large but suffer from decreasing returns but so what syndrome. i suggest you try not to contract that disease.
and of course i would be remiss if i didn't suggest that fmic don't belong on the optimally engineered fd unless you have a gig in the next Fast and Furious 12.
howard coleman
Old Jan 16, 2005 | 09:47 PM
  #59
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
I'll add my 2 cents.. since I owned a PFS IC..
I think its a wonderful IC. Only thing I recommend is that the 2 screws that holds the duct to the IC, if you dont use it, it will leak air. So, use it and use the right bolts.
I've enjoyed my PFS SMIC.. I had to get rid of it because my aftermarket hood didn't close. Now I have SPOautos SMIC.. which I need to put in.. I also agree with Stephen.. and as alway with Howard.
Old Jan 16, 2005 | 09:55 PM
  #60
FDNewbie's Avatar
Sponsor
Phil, I Paypaled ya back your change for your thoughts... I'm just playin hehe
On a serious note, Stephen made his own IC?
Old Jan 16, 2005 | 10:10 PM
  #61
Herblenny's Avatar
He did.. He made it out of Sparco core.. Really nice one.. I can't wait to put it on..
Old Jan 16, 2005 | 10:14 PM
  #62
FDNewbie's Avatar
Sponsor
Niiice. Def. post some pics of it (in this thread or another) when you install it.
Old Jan 25, 2005 | 09:12 AM
  #63
cruiser's Avatar
Anyone running Koyo with PFS SMIC ? I am and the duct sits about an inch higher then the IC, thus screwing the duct to the IC is impossible and I had to duct-tape the opening to prevent air from leaking at the top of IC (although its not perfect and would like to change it).
Old Jan 25, 2005 | 04:46 PM
  #64
FDNewbie's Avatar
Sponsor
While we're at it, what did you guys use to cap off the round side duct in the PFS IC duct? (intended for use w/ the PFS intake)?
Old Jan 26, 2005 | 03:14 PM
  #65
cruiser's Avatar
Use a sock and a clamp :P
Old Jan 26, 2005 | 05:45 PM
  #66
FDNewbie's Avatar
Sponsor
As hot as the engine bay gets?! That sock would catch fire! LOL
Old Jan 26, 2005 | 09:35 PM
  #67
ptrhahn's Avatar
I used a black cap from a spray can, a silicon coupler, and two clamps.
It's amazing how much easier it is to get to the duct fastening bolt on that side without the PFS intake in the way. How many of you owners dropped the bolt in the fan shroud 4 times before getting the threads started? I could have strangled a certain New Zealander a few time for that.
Old Jan 26, 2005 | 09:55 PM
  #68
FDNewbie's Avatar
Sponsor
Peter, originally I had a makeshift plumbing tubing cap that was a little too small, but w/ a bit of weatherstripping around it, it got wedged inside the hole pretty well. A few months later, one time popped the hood, and it was gone lol. A few days later I was over at PFS, and I asked them if they had a cap for it (being that they make the product), they said nope. But Ray suggested exactly what you said - a cap from a spray can. They had about 20 spray cans on the shelf in the bay, and I tried EVERY SINGLE ONE lol. They were all too small to actually fit over the opening. You wouldn't happen to know a spray can of what, would ya? lol. (Now I know why Home Depot has so many spray cans w/o caps... )
OMG, don't get me started. Lets just say those magnetic extension things are my best friend. Getting the other bolt in, not to mention the TINY space for both nuts and screws used in the AST bracket they used...man...getting that on, off, and on again once was a FEAT...
Old Jan 27, 2005 | 09:01 AM
  #69
ptrhahn's Avatar
It was just a can of spray paint. It didn't go over the hole, it was the same outside diameter as the little tube that comes off the duct with the hole in it.... both coincidentally the same INSIDE diameter of a piece of intercooler coupling (2.75" silicon, I believe).
Old Jan 27, 2005 | 10:25 AM
  #70
FDNewbie's Avatar
Sponsor
Yea, I saw a couple that were pretty much the same diameter. Ok, so you stuck a silicone coupler on the INSIDE of the duct and paint cap. Then you secured the paint cap onto the coupler w/ the clamp, right? How did you fasten the coupler to the duct tho? Where did that 2nd clamp go?
Old Jan 27, 2005 | 01:18 PM
  #71
ptrhahn's Avatar
Nope. Silicon coupler on the outside of the duct outlet and paint cap (which are the same diameter)... just like coupling two IC pipes. Nothing goes inside the duct outlet.
Old Jan 27, 2005 | 01:36 PM
  #72
FDNewbie's Avatar
Sponsor
I'm slow lol. For some reason, I got the impression you put them on the inside Don't mind me...lol
