Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
1jz rx7 swap?
Old May 26, 2010 | 02:26 AM
  #101
MazdaJzX7's Avatar
Awesome, that's all i really need, as long as i can take a peek. Anything would help at this point. I hate to rush this project. i'm just crammed for time right now. Thanks for offering the assistance
Old Jun 7, 2010 | 04:08 PM
  #102
TrboSpdAnt's Avatar
Boost makes cars smile.
That's ****** sexy...
Mebbe Santa'll gimme one for the King of the Jews' birthday.
Old Jun 16, 2010 | 12:58 AM
  #103
MazdaJzX7's Avatar
well i finished my mounts yesterday, here are a few photos.
Attached Thumbnails 1jz rx7 swap?-motor-mount-1.jpg   1jz rx7 swap?-motor-mount2.jpg   1jz rx7 swap?-swap.jpg
Old Jun 16, 2010 | 05:08 PM
  #104
Cam_Ron's Avatar
Those look alot like what I came up with in my FC.
I just finished my wiring last night and started it up for the first time. Came to life on the second crank of the starter.
Old Jun 16, 2010 | 05:33 PM
  #105
TurboMazdaSpeed's Avatar
1.3L piston eater
heres some motivation http://www.youtube.com/watch?v=d5GIXWmFgj0
Old Jun 17, 2010 | 02:16 AM
  #106
MazdaJzX7's Avatar
ahh i hate wiring, definitely not my strong point any tips would helpful....... i even have the supra fuse box, do i use that one or the mazda fuse box
Old Jun 17, 2010 | 02:18 AM
  #107
MazdaJzX7's Avatar
OWWW thats sexy bro!!
Old Jun 17, 2010 | 06:03 PM
  #108
Cam_Ron's Avatar
I ran all new relays and fuses. I dont trust old factory wiring.
Old Jun 28, 2010 | 01:42 PM
  #109
FCinWV's Avatar
Rotary Haven
wow. That is some incentive. I have an FC that needs serious lovin'. The motor is out and I was open to all power options. i think I've found my swap plan. Thats the monster I'm looking for.
Old Jun 29, 2010 | 10:11 PM
  #110
Cam_Ron's Avatar
I recalibrated my tach and got the factory 1jz water temp sensor to read on my cluster the other night. My next step is to get the factory oil pressure gauge to work using a new fc pressure sensor.
Things are coming along nicely now, hoping to take it for a test drive this sunday.
Old Jul 13, 2010 | 08:25 PM
  #111
Cam_Ron's Avatar
My 1jz fc is running and driving! Unfortunately my ecu has 3 leaking capacitors Even with ridiculous overfueling, missfiring, and a high idle it hauls ***. Chirps 235's into third gear. I'm going to try my power fc tommorow night and see how that works ( Has a 335whp tune on it)
Old Jul 21, 2010 | 11:34 AM
  #112
Cam_Ron's Avatar
Heres a quick video of mine:
280whp, 305wtq (all between 4-5K) boost wont hold after that.
Old Jul 22, 2010 | 01:32 AM
  #113
fstbckgt's Avatar
Barrel Roll
^nice vid. think you could add some pics of your engine bay?
Old Jul 22, 2010 | 01:38 AM
  #114
Cam_Ron's Avatar
Just some old ones:
Am I the first 1j fc in Canada?
Old Jul 24, 2010 | 04:51 AM
  #115
fstbckgt's Avatar
Barrel Roll
nice. was hoping for some with the IC piping installed, i need to reroute mine eventually and wanted to see how yours are set up
Old Jul 24, 2010 | 06:55 AM
  #116
TrboSpdAnt's Avatar
I'm really glad to see this project is coming together, as easily as it is.
This doesn't sound much like a conventional swap, so anything that goes without a hitch is awesome!
Old Jul 28, 2010 | 11:20 PM
  #117
airquin23's Avatar
Team U.R.S
Imma be goin with a jz swap...not sure if I want a 1 or 2j. Good info on these pages. Probly go with a 1.5jz but we'll c. Fukn stoked!!!
Old Jul 29, 2010 | 04:02 PM
  #118
*TOUCH*'s Avatar
Project P --- Pedospeed
1.5jz ftw....
Old Jul 29, 2010 | 11:40 PM
  #119
TrboSpdAnt's Avatar
I've heard some really great numbers come out of 1-5J builds. When's that supposed to get underway?
Old Jul 30, 2010 | 08:32 PM
  #120
Cam_Ron's Avatar
when my 1j bottom end blows, a 2j is going into its place. Either the mounts or the hood are going to have to be adjusted to fit though
Old Aug 17, 2011 | 10:01 PM
  #121
eds13's Avatar
i know im wicked late to the thread, and the topic. BUT.
i am also interested in doing this swap. is there a huge massive right up anywhere or wiring diagrams, or any information that would be helpful at all out there?
Thanks
Ed
Old May 10, 2013 | 12:01 AM
  #122
luckyfd's Avatar
is that normal?
where's everyone?!
Old Sep 8, 2013 | 03:25 PM
  #123
danegerous's Avatar
it go down in the dm
Check the link in my signature, I've beat ( as well as JTP and Dan and Martin of PSM) on my 1jz Fc pretty damn hard. With video!
Old Jun 18, 2014 | 05:04 PM
  #124
FC_fan's Avatar
Sideways is the only way
I COMMAND THIS THREAD TO ARIIIIIIISE!
we need a really good wiring writeup for the 1jz swap. I recall sketch's build thread had some issue with the injectors not firing and he "bypassed" some stuff to get it running. we should have an appropriate wiring guide (diagram if possible but a tutorial too maybe). If I ever get to doing my 1jz swap I will write up my wiring but I'm no electrician. that might take years for me to get that far though idk.
Also, can anyone with the 1jz installed with tech 2's swap kit measure how far down the back side of the highest point on the valve cover is on the firewall? like from top of firewall to where the top of engine is. That way I can see when I make mounts if its sitting as low as it can go. I haven't heard anything of the trans mount so it seems that bolts right up with no issue or need to modify.
Old Jan 13, 2018 | 02:07 AM
  #125
fzkhan7's Avatar
Replied to wrong thread
