What OEM Mazda parts are you looking for/do you need?
I'm a little late to the party, but what the heck. This is what I'm looking for, sorry if it was already mentioned... I also didn't take the time to look up part numbers. Sorry 'bout that
I know there's other crap, but this is what came to mind first.
-oil cooler ducts & hardware
-brake ducts/plastics
-headlight bezels/plastics
-r1 trunk lid, carpet
-windshield washer resivior + cap
-differential bushing
-suede seats
I know there's other crap, but this is what came to mind first.-oil cooler ducts & hardware
-suede seats
- MudGuards (Front Set) OEM
- MudGuards (Rear Set) OEM
- Front Strut Bar (Inside Engine Bay) Typical Red with RX-7 lettering on it.
- R1 Rear Wing
- 93-95 Front Bumper Skin
- Door Sills (Black OEM ones)
- OEM RX-7 Rims
- Fuel Filter
- Driver Side Window Switch
- Plastic Coverings for Inside of Doors. (Inner Side of the Door Handles that covers the Door Handle Bolts. Plastic Triangular shape.)
- Front Corner Lights (Front Bumper OEM)
- Headlight Covers.
- Floormats
- R1 Rear Wing
- OEM RX-7 Rims
- Fuel Filter
- Headlight Covers.
- Floormats
Vacuum lines (all of the pre-molded rubber ones...)
Yeah silicone/ viton is better, but the're not pre-molded and normally I like my engine bay to look like it is intended to.
the rubber ones will be good for at least 30,000 miles.
Front windshield black surround moldings
Sunroof black moldings
Both driver and passenger weather strip and door strip
both driver and passenger door sills
push-in clips/rivets in black for rear bins, trim pieces etc.
My suggestion would be: How about Ray get someone to help him over at Malloy. I hate not being able to order parts whenever he's not in. I'm worried what'll happen if/when he leaves?!?
Easier said than done Riz......I've suggested it to him but you'd need someone with intimate knowledge of the FDs---interior, exterior, engine internals etc etc.
Front ball joints(2 needed) for 86 base model #34-5500-fb01
http://www.mazdatrix.com/hsteer2.htm
Center a/c vent for S5 model #64-8400-fc01
http://www.mazdatrix.com/in-stere.htm
Front control arm bushings (2 needed)(rear bushing) for 86 base model #34-4600-fby1
http://www.mazdatrix.com/h6_86-92.htm
Bump for the thread and Ray Crowe in general. I just called Ray to order an A/C high pressure hard line to which Ray does indeed know his stuff. Couple quick questions and on a car made in 1993, he knew based on what model what line to order since there were dealer installed A/C options and factory installed lines. Just wanted to say thanks to Ray for being spot on with his knowledge of the FD and helping us out as well.
Tim
Tim
Any news on the sale?
My wish list:
1. AC dash vents
2. Floor mats
3. Dashpot
4. Map pockets
5. FPD
7. AC compressor
8. Hood latch assembly
9. External Gasket set
10. Antenna
12. Door seals, window seals
13. Underbody plastics
14. Oil pressure sensor
15. Solenoid set
16. Door sills
My wish list:
1. AC dash vents
2. Floor mats
3. Dashpot
4. Map pockets
5. FPD
7. AC compressor
10. Antenna
15. Solenoid set
16. Door sills
