What OEM Mazda parts are you looking for/do you need?
there have been some good suggestions on here, such as bushings and ignition sets.
Also, fuel and oil filters.
As for my own needs, I need all of the gaskets/hoses/crush washers to replace my stock twins. I'd probably also include the coolant hoses that are hard to replace without removing the twins as well.
I have bought a ton of stuff from Ray already - pillowballs, upper shock mounts and associated bits, interior trim pieces... Ray always comes through.
I want to suggest that you take the time to go through the service manuals and quote the Mazda part numbers when you email Ray for parts. Makes his job easier and eliminates any ambiguity when describing parts.
The quote below is an excellent example:
- Headlight covers - I need a passenger one as I sit here and already bought a used VR painted driver side one
- Driver side power window switch
- bushings to stop the rear clunk
- OEM fan Belts which fit perfectly
- fuel and oil filters
- A/C compressors
- NON-OEM alternator more powe for modern audio/video
- A/C compressors
Thanks for all the suggestions guys, keep it coming
Within the next week or so there will be an announcement of the big summer sale taking into account your input
Hey Ray just wanted to say hi and that I was talking with Bill From houston and he said your the man for oem parts. Got a nice project and will most likely be talking to you sometime in the future...
Money, I'd recommend emailing Ray at hmkparts@aol.com for a quote.
Guys, the sale should be up sometime this week so stay tuned
Here's my wish list:
Lower LIM Gasket
Rubber pads for the trunk
Spark plugs
Check valves (Platic and metal ones)
Stock turbo gaskets and bolts
Injector kits (O-rings etc ...)
Hood insulation pad
Every crush washer for an FD ...
Oil pressure sensor
Stuff I don't need but that should be on the list:
Fuel and oil filters
Coolant hose kit
Front bumper lip
Chrome bezels for gauges
Lower LIM Gasket
Spark plugs
Hood insulation pad
Oil pressure sensor
Coolant hose kit
Front bumper lip
parts
I need a gauge cluster hood and another motor. They are the two big ticket items right now for me, since my OMP went out and took everything with it. The hood was already cracked when I bought the car, so since it's down, why not get one. Now all I need is some money.
