Rtek RTEK 7 v1.8 for s5?
Old Aug 9, 2008 | 08:02 AM
johnboost's Avatar
RTEK 7 v1.8 for s5?
hey i was looking at getting an RTEK 7 v1.8 for my s5 rx7 and just found that it is only listed for s4, can it work for a series 5? if not is there anything else on the market that will do the same job in a s5 for a similar price?
Old Aug 9, 2008 | 09:01 PM
therotorrooter's Avatar
S5 I think has different parameters and such. I believe there are differences in the overall wiring and control of each series engines, mechanical verses electrical control. Another informative site about this is rotaryresurrection.com Digitaltuning.com is working on the 2.1 version right now for the s5. I saw your post on what you are doing and I would definately consider the 2.1 version if you can wait for it to arrive. I'm putting a TII drive train in my 88 vert and am going to run the 2.1. My mods are going to be about the same as yours I think, hybrid turbo, REVII exhaust, street port with rotary aviations seals, fmic, bigger injectors and such. It seems like they were looking for beta testers for s5's , look in the rtek forum on here if you haven't already. Some people use fcon's and some greddy stuff I think, but as far as being able to adjust parameters, timing, and fuel control, unless you get a full standalone, I think the rtek seems like a pretty viable option. This is somewhat vague, I'm not an expert, but I hope it helps!
Old Aug 11, 2008 | 05:43 AM
johnboost's Avatar
thanks for the info dude but when do you reckon the 2.1 will be out? im not in any big hurry so i guess i can waight only i wanted to upgrade the fuel delivery system first as a safety barrier but what can you do? ill just have to chance it for a little while and run low boost r something.
Old Aug 11, 2008 | 01:47 PM
RotaryRocket88's Avatar
Top Down, Boost Up
You can use a SAFC-NEO fuel controller to regulate things too. Even running low boost with bigger injectors for safety, the car will be way too rich throughout the RPM range if you don't control it.
Old Aug 11, 2008 | 04:19 PM
The Griffin's Avatar
Burning up Time
They are beta testing S5 versions of the 1.8 now.May want to email them as to the progress.
https://www.rx7club.com/rtek-forum-168/s5-tii-testers-wanted-750038/
WyomingTII
Rtek Forum
Oct 26, 2015 05:26 PM
lnlreaper
Sep 27, 2015 09:59 AM
