AVCR Question
Old Aug 15, 2007 | 05:20 AM
kerry chandler's Avatar
AVCR Question
My avcr boost display reads -28mmhg intead of 0.00kg with ignition on engine not running.Any ideas how to calibrate to display 0.00?
Old Aug 15, 2007 | 08:53 AM
DaleClark's Avatar
RX-7 Bad Ass
There's nothing that I know of for calibration. I THINK you can pick different sensors in the Etc. menu - make sure the "stock" sensor is selected if so.
Might also want to make sure the grounds are properly installed. There are 2 ground wires, and they need to be attached to the same ECU wire with one closer to the ECU than the other. A flaky ground could cause an error in reading.
I believe mine shows 0 with the engine off.
Dale
Old Aug 15, 2007 | 01:04 PM
Thanks Dale, yeah picked Relative 1 on sensor settings thats whats recommended
on manual but no good. Its not out by much, guess i can live with it,works fine anyways
Old Aug 16, 2007 | 03:02 AM
nvmyre's Avatar
i dont think it is meant to read 0 when not running mine doesnt and when running it still doesnt read 0 i have done a fir bit of work to my car and if there was a problem with it we would know
_Tones_
Adaptronic Engine Mgmt - AUS
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
