Q about TPS
Old Sep 1, 2006 | 10:08 AM
90WhiteVrt's Avatar
FC4ME
Q about TPS
My TPS isnt working at all right now and i'm wondering what type of hp loss that would cause. thanks
Old Sep 1, 2006 | 11:27 AM
SureShot's Avatar
Seduced by the DARK SIDE
That depends on how it's not working.
If it's unplugged, you won't get the deceration fuel cut, which is more of an issue in stop-and-go driving.
Power will be fine, but gas mileage will be worse.
If it has some worn out bad spots, you will be getting erratic fuel cuts while driving.
That type of power loss will be real obvious.
It you have an S5 & the wide range TPS fails, the ECU will put you in "limp home" mode.
The S5 narrow range TPS works just like the S4's.
Old Sep 1, 2006 | 01:37 PM
90WhiteVrt's Avatar
FC4ME
^When i tried to adjust the TPS w/ another forum member said it wasnt responding at all.
Old Sep 8, 2006 | 01:32 PM
SureShot's Avatar
I just clip an ohmmeter on the TPS, pull off the fast idle cam & set it to 1K ohms.
Then, while the meter is on, work the plunger to check for bad spots.
Old Sep 8, 2006 | 02:25 PM
mikaz's Avatar
The Extremist
how do you pull off the fast idle cam?
Old Sep 8, 2006 | 05:42 PM
90WhiteVrt's Avatar
FC4ME
I just got the new TPS installed and i'm wondering if anyone can give me a link to a site that tells you how to adjust the S5 tps. I've searched the forum and found alot of S4 and turbo references, but nothing for the S5 N/A.
LongDuck
12
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
