Rtek Streetport on 1.7?
Old Jun 16, 2006 | 02:22 PM
Digi7ech's Avatar
I break Diff mounts
Streetport on 1.7?
I've got a SP and am contemplating getting 720's and 1.7 to help with fuel.
You think it can handle it?Maybe only run 10psi?
I can't afford the 2.0 yet so this is a bandaid fix since I've already got 1.5 so it's $25 to go to 1.7.
Old Jun 17, 2006 | 03:16 AM
demahfahbun106's Avatar
Psychotic CRITIC™
sure
i dont see why not...plus you said you going to be runnign 10psi, even better
Old Jun 17, 2006 | 06:14 AM
brooklynfc3s's Avatar
are u really sure? If you've got money invested in your motor, I wouldnt risk it. You cant make any corrections with the 1.7. at least get a 2.0 and tune on a wideband or something.
Old Jun 17, 2006 | 04:10 PM
Digi7ech's Avatar
I break Diff mounts
Well. I guess it should hold pretty well.
The engine just eats more air and all the ECU does is add fuel dependant on the AFM readings. The AFM will be noticing the increased air so it will match it.
As long as the 720's don't hit their max I should be fine.
So if on stock port a 1.7 can hit 12-14psi then a streetport at 10psi may be relatively the same.
I think I'm going to run stock levels and try and borrow a wideband to see how far up I can go before it starts going lean.
I would prefer to just run 10psi still.
Old Jun 22, 2006 | 04:17 PM
Digi7ech's Avatar
I break Diff mounts
Got the 720's and stopped by Digital Tuning today to get my ECU redone.
I expected to just drop it off.
He kicked *** and did it on the spot for me AND i got a cool license plate frame.
Old Jul 2, 2006 | 03:20 AM
drugblock12a's Avatar
WON'T FORGET DAVE
I am planning on useing the 1.7 on a streetported 87 T2 block. I don't plan on running anymore than 10 pounds. If anyone has run a similar setup please chime in.
1987 T2
11
Apr 1, 2017 11:59 PM
erick31876
Sep 23, 2015 05:16 AM
WANKfactor
Sep 15, 2015 07:45 AM
