Rtek Fuel cut on a rtek 1.7
Old Jun 14, 2008 | 05:54 PM
Brody8877's Avatar
#FakeCarEnthusaist
So i am hitting fuel cut in 2nd gear around 6psi @+/- 5000rpm. I have rtek 1.7 which has a built in FCD. WHy am i hitting fuel cut? I have check the tps make sure it is in spec and I check most of the electrical connection. What else can cause fuel cut?
Old Jun 14, 2008 | 06:29 PM
arghx's Avatar
rotorhead
what makes you think it's fuel cut? Unless there is a problem with the Rtek (not likely), you are not hitting boost-induced fuel cut. The Rtek 1.7 essentially deleted the code in the stock ECU for fuel cut. You have another problem, such as a clogged cat, sever ignition breakup, or serious detonation.
Old Jun 14, 2008 | 07:58 PM
Brody8877's Avatar
#FakeCarEnthusaist
I cant redline my car, in 2nd gear i cant go past 5000rpm and in 4th gear 4500rpm. Its seem like fuel cut because it feels like hitting a brick wall and I know how fuel cut feels like. Also I am running a RB full turbo back.
Old Jun 15, 2008 | 12:17 AM
Brody8877's Avatar
#FakeCarEnthusaist
im trying to think, and it doesnt make sense. My car was running fine after i got my car out from a shop. After i reinstalled my high flow cat to get the car smog it started to act up.
Old Jun 23, 2008 | 01:17 AM
SpikeDerailed's Avatar
This sh*t burns oil!
Most standard cheaper hi-flow cat setups cant withstand rotary exhaust temperatures. Throw a test pipe in it and see if it still acting up, arghx already mentioned possible clogged cat.
alphawolff
17
Nov 17, 2015 05:57 PM
Snook
21
Sep 1, 2015 06:32 PM
armans
Aug 15, 2015 09:08 PM
