s5 engine s4 tranny, what clutch?
Old Nov 5, 2007 | 10:30 PM
DREYKO's Avatar
I "lost" my emissions....
my engine is a 91 n/a tranny is a 88 n/a
what clutch do i need?
Old Nov 5, 2007 | 11:45 PM
misterstyx69's Avatar
Retired Moderator, RIP
You need an N/A Clutch...Unless the Splines are Different between the S4 and S5 transmissions,which I don't think they are...Now if you changed to a TII trans,then it would be a different story...just because the engine is S5 and the Trans is s4,It should have no Relevance to what Type of clutch you require..(if you are running a light flywheel you would need the Counterweight for THAT ENGINE.)..anyhow,here is an example of a good clutch for you.And Notice that the INFO states "for 86-91".. http://www.andysautosport.com/mazda/...ch_kits/exedy/ hope that helps.STYX.
immanuel__7
89
Sep 5, 2015 10:23 AM
sYnth.
Aug 19, 2015 06:27 PM
Wicked93gs
Aug 17, 2015 12:14 PM
