Wheel Fitment
Old Jan 26, 2007 | 11:29 PM
TOOSHORT_88's Avatar
"On the grind"
Wheel Fitment
im about to buy some wheels 18x8.5
front 235/35/18
rear 265/35/18 offset is 40
what will need to be modified to make em fit?
Old Jan 27, 2007 | 01:13 AM
Black91n/a's Avatar
For the front you'll need some 10-15mm spacers, which will require longer studs, and you might have to roll the fenders. The rear should fit ok, but might need a thin spacer. These studs should be plenty long for the front:
http://store.summitracing.com/partde...5&autoview=sku
Old Jan 27, 2007 | 01:33 AM
"On the grind"
Thank you for info .
where can i get spacers from?
Old Jan 27, 2007 | 11:30 AM
Black91n/a's Avatar
Summit Racing, maybe your local auto parts store or tire shop. You'll probably have to order them in inches though, not a hard conversion.
Old Jan 28, 2007 | 11:56 PM
"On the grind"
So i bought those wheels and they fit perfect in the rear but in front it barely rubs against the spring. stock TII looked like a monster truck man. I had like 3inch plus in fender well clearance same on the rear fender wells. If i choose to go with suspension setup what will fit? and how many mm spacers do i need. Man i really need to lower her .
thks
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
