Rtek Rtek 2.0 Low end improvement?
Old Jan 9, 2007 | 10:16 PM
rb240z71's Avatar
Hey guys, I was just wondering if there's anything I can do on the settings for the rtek 2.0 to improve low end throttle response and street driveability (2000-3000rpm).
I'm running 720cc x 4, HKS Dragger exhaust, stock s4 turbo (upgrade soon) peak at around 10 psi.
Will running 500cc primary and 720cc sec. help? How about riching or leaning the fuel map?
BTW, will a S5 turbocharger make a lot of improvement compare to a S4 turbo?
Thanks
Old Jan 9, 2007 | 10:22 PM
JWteknix's Avatar
s5 turbo does make more power but not enough to make that big of a difference 550s might help ull need a wide band to see weather or not you will need to richen or lean the a/f ratio out and if your not expeirienced i wouldnt go messing around with the ems take it to someone to get it tuned thats the best advice i can offer you
Old Jan 9, 2007 | 10:38 PM
rb240z71's Avatar
Thanks for the reply. Yes I'm looking into innovative wideband o2 sensor for tuning. Most def. on the wideband when I get the turbo upgrade.
Do you think lighter flywheel help low end?
Old Jan 15, 2007 | 02:29 AM
Henrik's Avatar
Is your user name accurate? If so, I'de love to see pics (I had a '72 before I got my TII).
2000 is getting to the lugging end on a TII. As for settings, tune the fuel map with a WB.
-Henrik
Old Jan 15, 2007 | 02:27 PM
rb240z71's Avatar
Yes, I have a 71 Datsun 240z with a RB25det swap. Everything is in the car already just need to wire the whole thing up. I took out all the stock wiring because it's shorting everywhere so I got a EZ wiring kit. Haven't work on that car for a long time, it's just sitting in my garage. Hopefully find some time to work on it and make it run soon!
As for the rx7, I'm going to get a WB for tuning in the near future.
Queppa
Nov 18, 2024 03:47 AM
astrum
24
Nov 15, 2017 08:44 AM
smikels
Rtek Forum
May 12, 2016 12:34 AM
eddierotary
Rtek Forum
Aug 25, 2015 05:48 PM
baconflavored
SE RX-7 Forum
Aug 12, 2015 12:07 AM
