FDNewbie Imports FDNewbie Imports: OEM, aftermarket, and rare JDM parts specialists. We ARE the forum JDM Junkies!
GB for racelogic
Old Jan 28, 2008 | 08:59 AM
  #376
calculon's Avatar
On flats
Thank you for the update.
Old Feb 11, 2008 | 12:26 PM
  #377
Mdessouki's Avatar
Trying not to get off topic but can someone recomend a shop in the DC area that can install one of these?
Old Mar 13, 2009 | 01:42 PM
  #378
Max_Spd's Avatar
UA DRVN
Hey guys, need help with installing the Unit, but there is lack of full detail i need for the install within the forum...
This is for all those that have installed their own units or done it for someone else...
As i stated in the post, i am in the process of installing the unit myself...
I have the 6 cylinder version...
My questions are:
1. Where is the wire for the clutch shift? My unit did not come supplied with the wire...is it something i have to plug into the main harness? And also, which wire color on the clutch switch did you connect the thing to...(not sure if there is 1 or more wires...have not looked at it yet)
2. I dont have the A/C anymore in my car...will the hook up to the condenser still work as power on?
3. What main fused power wire (location/color) did you hook up the unit to? (its not suppose to go to ground during cranking)
4. Lastly...Does it matter which injector goes to which color wire...i know they have to stay the same (red with red/black) for in and out as well, but how does the user know which wire from RLTC knows which unit it corresponds to in terms of color of the factory/injector? I know it does not matter with the ABS wires as the diagnostic procedure will make the unit figure out which wheel sensor is which...but not sure of the Fuel...
Thanks...
Old Mar 13, 2009 | 02:42 PM
  #379
Juiceh's Avatar
Saiga-12 Power!
Originally Posted by BlueRex
The 20B RR Program is here. I'll see if I can get it out Monday or Tuesday.
I never did receive this.
Max_Spd: I dunno the answer to your question as I have not even got to take both of my units out of the boxes to install them yet. But, please do come back here and give us your views on the system once you have it working.
Old Mar 16, 2009 | 01:09 PM
  #380
T2 vert's Avatar
I am in need of the analog Adjuster for my TC, I think mine is bad. I am hoping someone who bought the Digital Adjuster would sell me there analog Adjuster. Give me a PM
Old Sep 5, 2010 | 04:29 AM
  #381
aoc007's Avatar
I was thinking, how well would my racelogic work when I install methanol auxiliary injection? It won't control that.
Old Sep 5, 2010 | 01:11 PM
  #382
legendrx7's Avatar
Rotarded since 1992
I had the same thoughts and concerns. That is why I am going with a full custom meth setup. I'll be using two fuel injectors mounted in the primary location that will be pumped with meth and will receive the same signal as my secondary injectors. I ended up sizing my meth injectors to be 750cc. I got an Xcessive LIM to mount my gas primaries.
The meth setup will have a 4 gallon cell in the hatch area ran with SS hard lines, meth compatible filters, pump, and FPR. I've got everything to do the full setup, but I cracked a couple corner seals on my motor and I'm letting my motor builder take his time with the rebuild. So, in the meantime, I hope to get most of the meth install done and finish everything up when I reinstall the motor. Probably won't be running until early next year but I'm hoping for good results and I'll have piece of mind knowing that the meth will be cut out at the same time as the gas.
Old Sep 5, 2010 | 02:25 PM
  #383
RotorMotor's Avatar
DRIVE THE ROTARY SPORTS
I'm wondering the same myself.... does anyone have the 20b program?
Old Sep 5, 2010 | 05:46 PM
  #384
str8ryd's Avatar
Nearing Completion...
I have it somewhere...
Old Sep 5, 2010 | 11:09 PM
  #385
RotorMotor's Avatar
If you still have it, care to share?
Old Sep 9, 2012 | 11:58 AM
  #386
4CN Air's Avatar
DETH TRP
If anyone missed out on this, I have a unit with analog controller for sale. $1000 shipped.
stickmantijuana
20B Forum
Sep 22, 2015 01:10 PM
rx7rs02
13
Sep 9, 2012 03:29 PM
palsor1
Auxiliary Injection
Sep 23, 2010 04:04 PM
StrikeRx7
20
Mar 11, 2009 04:26 PM
