HELP! Screwed up big time, dropped nut INTO engine!
Old Dec 24, 2001 | 12:53 PM
jr's Avatar
jr
Exclamation HELP! Screwed up big time, dropped nut INTO engine!
I'm shitting bricks right now, I was pulling my intake manifold off and I had a nut in my fingers as I was ligting it off and the damn thing fell into the far left hole on the lower intake manifold. I tried fishing around in there with a magnet, but I haven't come up with anything yet. Anyone have some suggestions? I'm gonna shoot myself for being so stupid.
Old Dec 24, 2001 | 01:11 PM
fcturbo2's Avatar
Re: HELP! Screwed up big time, dropped nut INTO engine!
[QUOTE]Originally posted by jr
I'm shitting bricks right now, I was pulling my intake manifold off and I had a nut in my fingers as I was ligting it off and the damn thing fell into the far left hole on the lower intake manifold. I tried fishing around in there with a magnet, but I haven't come up with anything yet. Anyone have some suggestions? I'm gonna shoot myself for being so stupid. [/Q
OK. Im assuming that the nut is in the chamber now. Well here is what i would do. SIMPLE!..remove the whole intake system including the turbo and manifold. Turn the engine manually untill you can get to the apex seal area. Use your fingers to feel the nut thru the exaust ports. Most likely it will fall thru the exaust ports. If not successful with the first try then turn the motor again (manually till you hit the other apex of the rotor. GET my point???..GOOD LUCK!..let me know if it worked!
FCTURBO2
Old Dec 24, 2001 | 01:35 PM
jr's Avatar
jr
Ugh, I was afraid it was going to come to that. At least I noticed that it dropped, otherwise I'd be buying a new engine. Thanks.
Old Dec 24, 2001 | 01:36 PM
GsrSol's Avatar
Z06 powered FD
Keep trying with the magnet, bend the magnet and everything. It has to be in there on the side of the rotor where you dropped it.
Old Dec 24, 2001 | 01:41 PM
HedgeHog's Avatar
Rotary Poseur
vacuum cleaner?
Old Dec 24, 2001 | 01:48 PM
Rotary93's Avatar
Retired RX7 mechanic
Try a really strong magnet.....It should work
Old Dec 24, 2001 | 01:51 PM
martini's Avatar
I would try a magnet first as well..I would not want to turn the thing,
Old Dec 24, 2001 | 02:05 PM
Bacon's Avatar
IRS 4 Life
damn
yea go to store and buy every kinda magnet pick up tool avable, theres like 10 diff kinds. i had one with a nuice flexy shaft and a strong *** magnet, but my friend borrowed and lost it...
if the magnet still dosent work, u can a, remove uim and then have direct acess to the chamber, since you havent rotated the engine it will still be in the chabler it fell into... id recomd not rotating the engine b/c if its not in the chambered part of the rotor you will scrach and damage the housing and rotor... if you still cant get at it then u might wana try and find a local shop with a boroscope..u know the little fiberoptic camera...it might be a worst case senario but still cheaper than turbos/engine...
best o luck man, just remeber not to freak out more than you have, take your time and think everying through, one false move could cause you more trouble than you in..try to keep calm..it WILL be ok..
Old Dec 24, 2001 | 03:14 PM
jr's Avatar
jr
Thanks for all the suggestions and encouragment, I appreciate it. I'll keep you posted on the results.
Old Dec 24, 2001 | 04:34 PM
jr's Avatar
jr
Got it! Thanks to everyone especially HedgeHog for the vaccum idea, here's what I rigged up:
http://63.108.11.6/jrspics/Vacuum1.JPG
http://63.108.11.6/jrspics/Vacuum2.JPG
And here's the f$%&ing nut:
http://63.108.11.6/jrspics/Goddamnednut.JPG
I feel so much better now, whew. Thanks again.
Old Dec 24, 2001 | 05:23 PM
Crackers's Avatar
I can't stop laughing that has got to be the funniest bolt collection contraption I have ever seen.....
Sorry I know your nut exsperiance wasn't funny but what is funny is the after math of getting it out and how you procceded to do it.
Good job man Mad Props to your new invention
Nut in the rotery extration tool........
Old Dec 24, 2001 | 05:26 PM
jr's Avatar
jr
Hey, I should market this thing....
Old Dec 24, 2001 | 06:26 PM
Crackers's Avatar
Can I ask why you were taking the intake off?
Old Dec 24, 2001 | 07:08 PM
jr's Avatar
jr
I've been having boost problems ever since I did the silicone hose job. I've dignosed pretty much everything I can without pulling the manifold and checking the solenoids. I already found one pinched hose but it's part of the ACV system. I also cracked my ACV and need to replace it. I picked one up from Bacon's Wrecking Yard of South Jersey ( ) .
Old Dec 24, 2001 | 09:50 PM
Bacon's Avatar
IRS 4 Life
LMAO
Old Dec 24, 2001 | 10:12 PM
Falcon's Avatar
Have to give you credit for ingenuity. I'm sure you were stress-relieved "striking it gold"!
Glad to see good things still happen.
Old Dec 24, 2001 | 10:23 PM
Blue Goose's Avatar
necessity is the mother of invention...
Old Dec 24, 2001 | 10:39 PM
GsrSol's Avatar
Z06 powered FD
Glad you got it.
When I first looked at the pic, I thought all that **** in the vac collector came out of your engine. lol
Old Dec 24, 2001 | 11:55 PM
Toadman's Avatar
Nomad Mod
Good job and LMAO! Now check the vacuum can for an apex seal.. :p
Old Dec 25, 2001 | 12:05 AM
Wicked7's Avatar
Thats just about the funniest screw up I've ever seen. Good save though
Old Dec 25, 2001 | 12:54 AM
martini's Avatar
good show jr..
now you need some swirl remover for all those swirl marks I see in your paint.
Old Dec 26, 2001 | 06:48 PM
RecKleSs's Avatar
Adrenaline
Talking
JR, you are too funny. First it was the tie-wrap, which took you forever to finish and now it's a nut. Maybe you should just pay someone to fix your problem with your boost. Anyway, good luck with your FD.
Old Dec 26, 2001 | 06:57 PM
Cap'nWankel's Avatar
what is LMAO?
Old Dec 26, 2001 | 07:52 PM
Bacon's Avatar
IRS 4 Life
Laughing
My
Off
Old Dec 27, 2001 | 12:03 AM
kelrx7r1's Avatar
TNC
Talking LOL
damn thats funny as hell
at least it worked
good luck on fd
astrum
24
Nov 15, 2017 08:44 AM
smikels
Rtek Forum
May 12, 2016 12:34 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
