clearancing side seals...
Old Jan 13, 2004 | 07:16 PM
93BlackFD's Avatar
built my own engine
clearancing side seals is a PITA- i'm using the "hand file" method rather than the grinding wheel approach
that is all
Old Jan 13, 2004 | 08:13 PM
CCarlisi's Avatar
Rebreaking things
I think it's really cool you're learning how to do a rebuild. It doesn't make up for the trouble you've had with your engine, but it's something positive nevertheless.
Old Jan 13, 2004 | 08:30 PM
93BlackFD's Avatar
built my own engine
thanks
yeah, and i've been getting coached by steve kan and rick engman
so i think i'm in good company
i tried to port myself, but i quickly realize that it's not something i want to experiment with (in the interest of getting my car on the road)
so i'm letting steve kan @ gotham racing do the port work....what size port? well that's a secret...but it's bigger than a large street port!
Old Jan 13, 2004 | 08:37 PM
93BlackFD's Avatar
built my own engine
oh yeah, and i had rick engman (builds 4rotors for jim downing's lemans cars) press in the bearings for the rotors and stationary gears, he also polished the eccentric shaft, installed the pilot bearing, and lapped the irons....
new oil pan, pump, chain, thrust bearings, rotary aviation seals....and i have the peace of mind knowing that all of the stated items will be installed in the motor, whereas when you purchase a laundry list of "mods" in your motor from a company, you place a lot of trust (your life and your passenger's life) in that motor...
after seeing pics from this thread:
http://www.nopistons.com/forums/inde...ic=33569&st=25
i am glad i am doing this myself, and not running a re-rebuild
Old Jan 13, 2004 | 09:20 PM
jspecracer7's Avatar
1JZ powered
grinding wheel = good
Old Jan 13, 2004 | 09:29 PM
clayne's Avatar
PV = nRT
I've always loved the Rotary Engine Building and Porting forum on NP - a lot of knowledgable people there.
Old Jan 13, 2004 | 09:33 PM
BigIslandSevens's Avatar
What Irons did you use? AS well as rotor housings?( I assume new rotor housings, but, are the irons from your pineapple motor or another spare engine you had laying around?) I have been thinking of sending my engine to steve and have some magic ports put in!,Then rebuild as you are.( It's been over 1 1/2 years since last movement) Keep us posted and some progress pics.( which I'm sure you'll have) Good job, And your quote at the bottom of your sig couldn't be more true!! Dave
Old Jan 13, 2004 | 09:44 PM
93BlackFD's Avatar
built my own engine
i bought a low compression core from mazmart (www.mazmart.com) for $500...
turns out it was from a reman that had new irons, e-shaft, and stationary gears
Old Jan 14, 2004 | 01:55 AM
1JZ powered
LUCKY!!!!
Old Jan 14, 2004 | 08:29 AM
93BlackFD's Avatar
built my own engine
my total seal kit pricing was $430.19+$168 (rotary aviation seals) + $100 for atkins 1piece corner seals/springs
so that's not too bad, considering....
steve's port pricing is VERY competititve, and the ports are proven!!
i'm also looking forward to letting him tune it
Old Jan 14, 2004 | 11:02 AM
dubulup's Avatar
development
Upgrade those twins!
Old Jan 14, 2004 | 02:53 PM
93BlackFD's Avatar
built my own engine
no need, twins are plenty to satisfy my need for speed at the moment
i mean seriously, i daily drive a automatic 93 SOHC maxima....anything below 3psi will feel amazing at this point
Old Jan 14, 2004 | 08:04 PM
93BlackFD's Avatar
built my own engine
http://www.nopistons.com/forums/inde...howtopic=33754
Old Jan 14, 2004 | 09:16 PM
Choser's Avatar
Ugh. That's just disgusting.
Who can you trust to do a good rebuild?
Old Jan 15, 2004 | 08:28 AM
93BlackFD's Avatar
built my own engine
yourself!
Old Jan 15, 2004 | 11:24 AM
93BlackFD's Avatar
built my own engine
i just got the first set of pictures of the port work from gotham racing....WOW
artwork....pure artwork
i love being updated on the progress of my motor with pictures and online corrospondence...much better than waiting days on end....
vqturbo
Old School and Other Rotary
32
Aug 11, 2023 07:29 PM
Monsterbox
Jul 29, 2022 10:48 PM
Professorpeanutrx7
Aug 18, 2015 03:09 PM
