Is this where i Connect the "Fuel Cut Controller"... ? "PICS"
Old May 15, 2005 | 07:17 PM
theone81's Avatar
Red face Is this where i Connect the "Fuel Cut Controller"... ? "PICS"
the Square box is EGI and the Other Rectangular is ABS (which isn't were it goes) and 2 connecters in the corner there.... .I currently have a "Racing Beat Plug N Play Fuel Cut Controller"... any help will be nice before i start Pulling things off...
Michael
Attached Thumbnails Is this where i Connect the "Fuel Cut Controller"... ? "PICS"-picture-143.jpg   Is this where i Connect the "Fuel Cut Controller"... ? "PICS"-picture-144.jpg   Is this where i Connect the "Fuel Cut Controller"... ? "PICS"-picture-145.jpg
Old May 15, 2005 | 07:51 PM
Windsor, Ont
uhh, dosent it plug into the pressure sensor, UNDER THE HOOD?
well, thats where every one I have seen/installed so far goes.
Old May 15, 2005 | 08:01 PM
therotaryrocket's Avatar
PIMP
i plugged mine to the pressure sensor.
Old May 15, 2005 | 08:06 PM
SonicRaT's Avatar
Super Raterhater
If you don't know where to plug it in, or how the thing even works, you shouldn't use it.
Old May 15, 2005 | 08:23 PM
theone81's Avatar
the HKS Fuel cut gave Instrutions locate underneath the Carpet on the passanger side.
Old May 15, 2005 | 10:19 PM
eriksseven's Avatar
Make Money.
If you have a RB FCD, don't pay any attention to what HKS says...
The pressor sensor is a little 2"x 1" black plastic box located behind your airbox. It has a hose going into the bottom of it, and an electrical plug attached to it. Plug the FCD into this connection. Very simple.
Old May 15, 2005 | 10:59 PM
theone81's Avatar
Cool
its a Fuel Cut Controller not a Fuel Cut Diffuser..? or is that the same...?
Attached Thumbnails Is this where i Connect the "Fuel Cut Controller"... ? "PICS"-fuel-cut.jpg
Old May 15, 2005 | 11:17 PM
theone81's Avatar
whats the differrence between a FCD AND A FCC.... ????
Old May 15, 2005 | 11:53 PM
RotaryResurrection's Avatar
uuhhhh...maybe you should just leave this alone. By the sound of it, if you mess around too much plugging stuff in where it doesnt belong, your wipers might start turning when you hit 8 pounds of boost...
alphawolff
Nov 17, 2015 05:57 PM
Snook
21
Sep 1, 2015 06:32 PM
armans
Aug 15, 2015 09:08 PM
