rtek 1.7 or hks fcd
Old Nov 3, 2009 | 06:00 PM
  #51
bad 83's Avatar
PSHH! PSHH! HEAR ME NOW?
Quoted straight from R-Tek's website.
"550cc secondaries are stock so no change has been made to the fuel map in version 1.5. For version 1.7, the fuel map has been corrected to compensate for larger 720cc secondary injectors without the need for external fuel control, like an AFC, to keep from running very rich. If you have an AFC, it will no longer have to trick the ECU to compensate for the larger injectors. The AFC can be used for fine tuning. This also means that you CANNOT run version 1.7 in a car with 550cc secondaries or you will run lean. Likewise, version 1.8 is expecting at least 720cc injectors for both the primary and secondaries. Injectors with any less flow will run lean and can lead to engine damage. It is OK to run larger that the minimum injector size, but be aware that you will need some sort of fuel control to keep them from running very rich, or move to an Rtek7 Stage 2 ECU upgrade."
But I'm a dumbass that doesn't know what I'm talking about. Some people need to know what they're talking about before jumping someones ***, and calling them names. If you have any questions or want to know the TRUE info from R-Tek, just get the info straight from their website. http://www.pocketlogger.com/index.ph...4T2#secinjsize
Enough said.
Old Nov 3, 2009 | 07:59 PM
  #52
barney1omm's Avatar
STEP ASIDE !!!!!!!
wow
Old Nov 5, 2009 | 08:46 AM
  #53
GLC13B's Avatar
Rtek ecu
Great way to articulate your statement ! Nothing but hard facts.
Old Nov 5, 2009 | 08:51 AM
  #54
barney1omm's Avatar
STEP ASIDE !!!!!!!
it sure got quiet
Old Nov 5, 2009 | 10:12 AM
  #55
*prillaman*'s Avatar
chirp chirp
Old Nov 5, 2009 | 03:55 PM
  #56
bad 83's Avatar
It's funny how some people think they know what they are talking about, and are quick to act like a child and start spouting of a bunch of nonsense. Calling people names like this is highschool. If you don't know the facts, go straight to the source to find out. Do I need to say anything more?
Old Nov 5, 2009 | 05:10 PM
  #57
barney1omm's Avatar
STEP ASIDE !!!!!!!
my 1.7 and 750 s should be here fri. the 6th. my birthday btw.i cant wait to get it back to gather. i ll be in touch :}10mm
Old Nov 5, 2009 | 07:04 PM
  #58
Black Knight RX7 FC3S's Avatar
Turbo power, activate!
I hope you wont have any headache on your birthday from installing the parts haha
Old Nov 5, 2009 | 07:44 PM
  #59
barney1omm's Avatar
STEP ASIDE !!!!!!!
lol i got a buddy . that knows what hes doing ....................... i hope
Old Nov 6, 2009 | 01:20 PM
  #60
JCurry's Avatar
Shpee
i ran rtek 1.7 on my s4 TII at 12psi for like a year no problems... but there no reason to run the stock turbo above 12psi moreso if you still have the stock tmic! It wont be doin anything but making your IAT's go higher...
Old Nov 6, 2009 | 01:52 PM
  #61
barney1omm's Avatar
STEP ASIDE !!!!!!!
IAT S ????fmic soon
Old Nov 6, 2009 | 02:00 PM
  #62
JCurry's Avatar
Shpee
intake air temps
Old Nov 6, 2009 | 03:57 PM
  #63
barney1omm's Avatar
STEP ASIDE !!!!!!!
o.k.......front mount soon...now im worried bout my stock apex seals w 150 k on them.
Old Nov 6, 2009 | 04:53 PM
  #64
bad 83's Avatar
You should be
Old Nov 6, 2009 | 05:26 PM
  #65
djchiptoothsfc's Avatar
dj
^^^^^ lol!!
Old Nov 6, 2009 | 06:21 PM
  #66
barney1omm's Avatar
STEP ASIDE !!!!!!!
o.. thx,,::{
Old Nov 19, 2009 | 12:22 PM
  #67
barney1omm's Avatar
STEP ASIDE !!!!!!!
got back togather . what a bitch. runs great . wideband soon . had to do some tweaking to idle right. and tps adjustment.
Old Nov 19, 2009 | 01:39 PM
  #68
what you get done ?
Old Nov 19, 2009 | 04:27 PM
  #69
barney1omm's Avatar
STEP ASIDE !!!!!!!
1.7 - 750 s - s5 alt. - greddy bov - HOLY ****, SHE PULLS . 11 psi. more mods . soon.................10mm :}
Old Nov 19, 2009 | 06:20 PM
  #70
Rot8n87's Avatar
Another satisfied RX7 owner!
Old Nov 19, 2009 | 09:53 PM
  #71
nice man.. what you think shes layin down?
Old Nov 19, 2009 | 09:57 PM
  #72
Asterisk's Avatar
iRussian
Originally Posted by AUGieDogie
Bottom line, the 1.x series will probably need some way to control the fuel.
this will pulse the injectors at a rate to make it flow at stock fuel levels.
the 1.7and 1.8s DO NOT raise the amount of fuel delivered to your engine they just make the bigger ones flow the same as stock. If you plan on delivering more fuel then stock you WILL NEED a fuel controller.
That is wrong, wrong wrong. In fact this whole thread is full or fail, reading comprehension fail specifically. Why would RTEK adjust the fuel map to run bigger injectors, and then nullify that work to make it "flow the same as stock?"
You should read this, preferrably a few times, also from the same website you posted:
for anyone with any questions about the RTEK chip upgrades for the turbo FC3S, please follow this link, and be sure to click the "details" tabs for each of the functions listed, and read about the product some more. If you still have questions, then call the number on the website and ask any of the tech support people about the product.
EDIT: for people looking to make some extra power, this is a very reasonable guide to follow as far as tuning the FC:
http://fc3spro.com/TECH/FM2W/power.htm
lnlreaper
Sep 27, 2015 09:59 AM
