Canadian Forum Canadian users, post event and club info here.
Summer 2010 Updates On My Bridgeported Turbo-NA Project
Old Jun 23, 2010 | 01:19 PM
23Racer's Avatar
Aaron, two questions that I have wondered about for some time and I respect your knowledge and reasoning. The first question is how come in about 95% of the cases, all of the turbo changes result in the owner clamping a breather on the turbo inlet. Why doesn't anybody spend the time routing ducting to a cold air source. The turbo's have to be breathing really hot air from the rad and intercooler as well as radiated from the hot side of the turbo. It just doesn't make sense to me to have ginormous intercoolers and huge turbos then handicap them by having them work with 200 degree air.
Secondly, I love what you did to your suspension, basically other than the shocks, springs and bars, its the same as the one in my race car. I replaced the toe steer links with fabbed ones using a male and female rod end. This allowed me a certain level of setup flexibility along with adjustable subframe camber link I have. Its a pretty low cost mod and allows for better setups. Maybe an idea for the future?
Comments?
Eric
Old Jun 23, 2010 | 02:01 PM
Righty's Avatar
Very Hatefull.
Comments?
Eric
My guess is that the difference in temperatures under normal driving (atm vs engine bay) is very small. Small enough that it would be worse on power to restrict the turbo by adding a lengh of pipe.
OR
He prefers a cleaner engine bay.... lol
Old Jun 23, 2010 | 02:21 PM
Aaron Cake's Avatar
Engine, Not Motor
Originally Posted by Flash
Your exhaust is sounding pretty nice for a BP. I might have missed it, but are you using the same universal type presilencer as a year or two ago? If so, it sounds like it's holding up fairly well.
Real nice job on your redone intercooler BTW!
Yes, the same 3" Vibrant Ultra-Quiet resonator is still on the car. The addition this year was a 3" Vibrant bottle-style resonator. The ultra-quiet resonators are packed with stainless so I don't expect any real issues in the future with it. The bottle style is packed with something that resembles fibreglass, but isn't. I think it is some type of high temp ceramic cloth. It should be fine as well.
The intercooler changes seem to have made a bit of a difference in turbo response. But the downside is that I have noticed a slight reduction in cooling to the radiator. I'll need to add a duct to the undertray.
There's just no room to place it otherwise. I'd love to get some cold air to the filter but with the big turbo, intercooler piping and rad piping, there just isn't enough space. I have been considering building a shield to surround the filter and then ducting air from the space between the rad and intercooler for a little while. I can sneak an oval shaped tube over the rad hose to that metal area between the rad mount and headlight stuff.
I've seen the adjustable links before but didn't go with them for one reason: I don't know how to set them up. I don't think my level of driving could benefit from an adjustable suspension.
Old Jul 13, 2010 | 03:39 PM
  #29
Aaron Cake's Avatar
Engine, Not Motor
Just a quick little update that is too small for a thread of it's own.
THis winter I purchased a set of AWR engine mounts. However when I was testing the passenger side for fit, I found out that it didn't actually fit my car. THe wastegate runners on my turbo manifold run right past the stock mount and were too low, occupying the same space that the AWR mount wanted to take. So I put them aside for modification, but didn't actually get around to doing it...until now.
I grabbed a spare 2nd gen subframe and a bad center iron. Then I mounted the center iron to the subframe using the AWR mounts, and then welded support braces from the iron to the subframe. That way, the iron was locked in place and I could remove the passenger mount for modification.
The mount had to be lowered a lot, so first I cut it totally apart. I cut the upper part of the mount (the flange that bolts to the center iron) in half. Then I bolted in the bushing, held it up for a while, and decided where to tack it.
To connect the bushing to the subframe, I made a template out of cardboard before cutting any metal. The idea was to keep this part of the mount as low and away from the subframe as possible to eliminate any possibility of interference with the manifold runners, and to also keep it away from the heat.
Once the steel was cut, everything was heavily tacked together. I did a lot of tacking to try and keep warp under control during final welding. Unlike rubber mounts, these have very little play so there isn't much room for adjustment once installed. Note that I also cut two little triangle pieces that connected to the oil pan area of the mount. This provides much more weld area for the piece bolted to the bushing.
Because the mounts were powder coated from AWR, I sand blasted them prior to finish welding. Trying to TIG weld through powder coat is less then fun. I also welded a plate to the top of the subframe side of the mount for a bit more side-to-side rigidity.
After another sand blasting (actually, I blast with copper slag) I painted the mounts up with silver POR-15 (which closely matches the AWR silver powder coating) and then pressed in the bushings.
When the paint was dry, the mounts were installed on the car. It is such a pain in the butt to remove the stock driver side mount when the engine is in the car but the design of the AWR mount made installation very easy. The bottom bushing gets installed first but left loose. The top part then slips over the studs and onto the bottom piece before the bolt is passed through. I pre-assembled the passenger mount and then just angled it into place. Then I tightened up all the bolts and let the engine settle into place.
Any set of solid or poly mounts is going to transmit more vibration to the chassis, and I am definitely seeing more NVH (noise, vibration, harshness) under 3,000 RPM. But it is only a slight vibration and basically what I expected. Solid mounts used on stock port engines don't vibrate much at all. The engine is now held steady at all times, so the shifter feels far more solid. But best of all, the engine does not twist up an inch on the mounts at full throttle, which I know was stressing my solid rad pipes, intercooler piping, u-joints and transmission mounts.
Old Jul 13, 2010 | 07:52 PM
  #30
FC3Sdrift's Avatar
Displacement Replacement
do you notice any differance with the new gearing and LSD
Old Jul 15, 2010 | 08:25 AM
  #31
Aaron Cake's Avatar
Engine, Not Motor
I don't notice any difference with the change in gearing, but the LSD means that the rear is always more planted. I can be far deeper into the throttle without worrying the rear will come around, and 3rd gear really digs in now. I'm still losing traction on the 3rd to 4th shift, though less so now.
Old Jul 15, 2010 | 12:21 PM
  #32
vipernicus42's Avatar
Rotoholic Moderookie
As my Irish office-mate says, "F-ing Brilliant!"
Still impressed as ever. Can't wait to see this thing in person Aaron. She has turned out to be quite the beauty, and the attention to detail still amazes me.
Jon
Old Jul 17, 2010 | 10:29 AM
  #33
Aaron Cake's Avatar
Engine, Not Motor
Thank you!
Though it looks like I will be pulling the transmission to swap either the whole clutch assembly or just the pressure plate, becuase it did nothing but slip last night at St. Thomas Dragway. Best I managed was a 13.03 @ 114.
Old Jul 17, 2010 | 11:17 AM
  #34
barnett87rx7's Avatar
lite rotary = easy push
what size and type of tire are you running in the back? might be time to upgrade
Old Jul 17, 2010 | 11:49 AM
  #35
Bwek's Avatar
High Comp Booster
Time is slow for mph
Old Jul 17, 2010 | 01:23 PM
  #36
Aaron Cake's Avatar
Engine, Not Motor
215s. Yes, I know I need more tire. I think that I can probably get 235s or maybe even 245s on my rims.
Much, much too slow. The first run last night was highly disappointing. As soon as I went hard into 3rd gear, the engine just flew to redline as the clutch slipped. Over the next few runs I kind of figured out how to baby the clutch and was able to run 13.1s, 13.0s and around there by lazily shifting into 3rd and 4th. Even on a lazy shift, the engine RPM would kind of "slosh" down when I let out the clutch and there was no violence in it. Yet it doesn't slip on the street, probably because the wheels just spin.
I am very, very unhappy with the clutch people as I went on their recommendations.
Old Jul 17, 2010 | 07:48 PM
  #37
FC3Sdrift's Avatar
*cough* OS Giken twin disk *cough*
i see them used on here alot for 3-500
starting off is alittle ruff, once you get going you can shift nice and smooth... nothing beats how it grabs with hard shifts.
check these shifts out, you can just slam the gears
http://www.youtube.com/watch?v=j2hAF2FmTMs
Old Jul 18, 2010 | 10:15 AM
  #38
Aaron Cake's Avatar
Engine, Not Motor
That's one of the clutches I am considering. My concern is abrupt engagement, as I drive the car daily. I previously had a ceramic 6 puck (sprung) which didn't show any slip but it was quite hard on the flywheel.
Old Jul 18, 2010 | 07:14 PM
  #39
FC3Sdrift's Avatar
up until last fall I daily drove mine during the summers. once you get the hang of it its not even bad, i just got tired of spilling my coffee on the way to work lol
Old Jul 24, 2010 | 10:13 PM
  #40
Project88Turbo's Avatar
Stock boost FTW!
Great work as always Aaron. It is truly an inspiration to keep and keep working on my RX-7. In the words of one of my favorite quotes from GalaxyQuest, "Never give up, Never surrender."
Now, the real question now is this: What's in store for the Insight? Turbo? Crazy Aero mods??? Dilithium crystals to replace the battery pack?
Vince
Old Jul 25, 2010 | 10:40 AM
  #41
Aaron Cake's Avatar
Engine, Not Motor
The Insight is getting paint, but I don't know what else. I just had the injectors cleaned and made a few minor repairs it has needed for a while. At some point it will likely get MIMA.
As far as the RX-7, I discovered a cracked water pump housing on Thursday as I smelled coolant on the drive to work. The housing cracked near the thermostat neck, from age/fatigue as far as I can tell. So I've spent the last few days driving around my parents car as my Insight was in my shop for the aforementioned minor repairs....I have a new water pump housing prepared and ready to go on the RX-7.
Old Jul 25, 2010 | 11:32 AM
  #42
anees's Avatar
amemiya7
i wana put a super single os giken iin my FD
will it be still smooth as an OEM clutch?
and will it add any Horseppower to the car or no?
Old Jul 25, 2010 | 10:14 PM
  #43
ACTION RT's Avatar
G35 FTW
Insight getting painted your favourite colour too?
Old Jul 26, 2010 | 01:30 PM
  #44
Aaron Cake's Avatar
Engine, Not Motor
No clutch will ever add horsepower to a car.
Almost all aftermarket clutches that can hold more power then stock will engage more abruptly and have a harder pedal. While I have not driven a car equipped with a Single OS Giken clutch, I assume the same holds true for them as every other aftermarket clutch. More holding force = more abrupt engagement, harder pedal.
I'll be painting the Insight with PPG Anti-Freeze green as seen in this picture:
Old Jul 26, 2010 | 05:05 PM
  #45
anees's Avatar
amemiya7
dont take me wrong
why would any 1 upgrade the clutch?
Old Jul 26, 2010 | 10:17 PM
  #46
Nismo Convert86's Avatar
400WHP or bust
dont take me wrong
Old Jul 27, 2010 | 08:22 AM
  #47
Aaron Cake's Avatar
Engine, Not Motor
dont take me wrong
When you upgrade the engine and start making more power, the stock clutch will no longer hold.
jdayau
Nov 29, 2019 12:11 AM
ZacMan
Sep 19, 2015 09:20 PM
