Oiling system mods. (lots of pics!!!!)
Old Apr 5, 2008 | 06:21 PM
13B-RX3's Avatar
7s before paint!!!
I am performing all the oil system mods that i know of and thought i would share.
My objectives are.
1-No single passage smaller than 1/2" (including fittings).
2-No dual passage smaller than 3/8" (including fittings).
3-As few angled fittings and 90* internal passages as possible.
4-Block the oil galley in that goes trough the dowels (in case the dowel land brakes).
5-Be able to adjust the oil pressure externally (just do).
6-Minimize restriction on the oil pump pickup (turbulence).
7-Increase the oil system capacity (larger filter)
8-Regulate the oil pressure to the turbo without restricting flow.
I can't take credit for all of the mods. Some of them i pick up from reading over the years and some are my idea.
First are the mods to the oil pump passage. I did the standard porting and polishing but did not spend a tremendous amount of time on it.
I then knocked the plug out of the end of the oil pump galley and enlarged the passage. I feel that this is the biggest restriction in the whole oiling system. I reamed it out to 1/2 all the way into the oil pump cavity and then tapped it (18 X 1.5) so i could eliminate the oil passage that goes trough the front cover. I am also going to plug the bypass valve in the front cover.
Plugging the passage to the front cover and bypass valve.
Then i removed the casting flash from the oil drain back passage in the front iron.
Then i removed the galley plug for the front main bearing. I reamed the passage to 3/8 and tapped it (16 X 1.5).
13B-RX3's Avatar
7s before paint!!!
I enlarged the area where the banjo bolt for the turbo originally goes so i could tap and plug the galley (blocking oil from the dowels).
Thats about all the work i did on the front iron.
On the rear iron i made a oil filter adapter that eliminated the passage for the pressure regulator.
I reamed the rear main passage to 3/8" and radius the passage.
I still need to make the pickup and plug the oil passage to the dowels in the rear iron.
Here are a few pics of the plumbing of the system.
Here is a shot of the "Y" that will oil the front and rear mains. It is #10 inlet and #8 outlets.
Old Apr 5, 2008 | 06:22 PM
13B-RX3's Avatar
7s before paint!!!
Here is a picture of the oil line for the turbo going to the regulator.
And lastly, here are a few shots of the oil filter adapter with oil pressure adjustment. The #8 line from the adapter is the return from the regulator.
As i assemble and install the motor i will try and update this thread.
Old Apr 5, 2008 | 06:38 PM
Turblown's Avatar
Turn up the boost
I found it amazing at how terrible the factory designed the oil system.
Old Apr 5, 2008 | 07:51 PM
Chaotic_FC's Avatar
thats a beautiful setup you have there
more pics!
Old Apr 5, 2008 | 09:56 PM
justturbo2's Avatar
Registered User
real nice.
Old Apr 6, 2008 | 05:24 AM
CrackHeadMel's Avatar
Learned alot | Alot to go
Very nice, great write up and pics. There isnt alot of information spread around on this, hopfully someone will archive this
Old Apr 6, 2008 | 11:02 AM
ErnieT's Avatar
Living life 9 seconds at a time
Damn nice job!
Old Apr 6, 2008 | 10:10 PM
13B-RX3's Avatar
7s before paint!!!
Thanks everyone. It is hard to find a lot of info on oiling systems so i just wanted to put it all in one place. As i build the motor i will post up some more mods including sealing the oil pump without gaskets or paper.
Old Apr 7, 2008 | 05:27 AM
Marcel Burkett's Avatar
Wow !!! and here I am thinking that I actually modded my system !!!! amaizing work man !!
Old Apr 7, 2008 | 05:17 PM
t-von's Avatar
Rotor Head Extreme
Very nice! I especially like the idea of have an external pressure regulator. Is this incorporated with-in that oil filter adapter?
Old Apr 7, 2008 | 05:25 PM
13B-RX3's Avatar
7s before paint!!!
Yeah, it is made into the adapter. The 12 pointed nut and 5/16 bolt are the adjustment point.
Old Apr 7, 2008 | 06:54 PM
whereiscarmensandiego's Avatar
noob here no flaming but whats the benefit of all this?
Old Apr 7, 2008 | 07:02 PM
Where did you get that oil pedistal/regulator? ive looked for external regulators and was never able to find any.
Old Apr 7, 2008 | 07:09 PM
13B-RX3's Avatar
7s before paint!!!
eBay. It's a pull off from a circle track car of some sort. I paid $99 for it. I was going to make an external regulator but after i found the pedistle i decided to kill two birds at once.
http://cgi.ebay.com/ebaymotors/ws/eB...S%252BI%252BSS
Old Apr 7, 2008 | 07:15 PM
13B-RX3's Avatar
7s before paint!!!
The short answer is that when HP and RPM are increased beyond stock the oiling system starts to become inadequate.
Old Apr 7, 2008 | 07:29 PM
so like 400+ hp and trying to get 12k+ rpm this might be a good idea?
Old May 19, 2008 | 07:45 PM
Viking War Hammer's Avatar
*** Bless The USA
master lubricator
Old May 21, 2008 | 11:41 AM
Lee1's Avatar
lube master indeed.
Old May 21, 2008 | 05:19 PM
Stanello's Avatar
backslash beanbagrace
What did you use to block the upper dowel oil galley in the in the rear iron?
Old May 21, 2008 | 06:56 PM
13B-RX3's Avatar
7s before paint!!!
1/4 NPT plug.
Old May 21, 2008 | 08:14 PM
JTurtonRX_7's Avatar
EFR IWG 8374
hmm, i was unaware that the oiling system had so much room for improvement. For a 8k redline motor at say 14 lbs is there anything I could/should do when im already ripping it all apart to add dual massive oil coolers. That all looks like mods you do when building a new motor though
Old May 21, 2008 | 10:42 PM
hondahater's Avatar
spending too much money..
Good god man that is insane! I guess i missed what happend to your other motor? Was it oil issues?
Old May 21, 2008 | 10:51 PM
13B-RX3's Avatar
7s before paint!!!
Nothing oil related, more along the lines of 27 PSI on three piece seals. I will however need a stout oiling system for this beast https://www.rx7club.com/rotary-drag-racing-167/got-fuel-756944/
Plus all these mods were very cheap.
Old May 23, 2008 | 01:11 PM
hondahater's Avatar
So are you going with ceramic seals or 3mm seals next time?
edit: Damnnnnnn!!!! That freakin' setup is sick! Can't wait to see youtube of that thing running. Good luck man!
