Weber 45DCOE jet locations
Old May 15, 2007 | 05:29 PM
1badFB's Avatar
GSSL-SE
So Ive been reading up on weber carbs since I just bought one. I have found lots of usefull advice on most everything, except locating all of the jets/airbleeds/etc.
I seem to remember way back, seeing a picture of a 45DCOE with the top end removed and aarows pointing to everything listing what goes where.
While most of it I can figure out on my own, I thought that for other weber noobs an ultimate all encompassing weber sidedraft thread would be helpfull.
I plan to start such a thing if there isnt one on here already, but before that I would like to get some pictures together and make sure all my info is leading people in the right direction.
So, to start I just wanted to ask if there was a picture that locates the airbleeds/jets/etc needed to tune a weber 45DCOE.
If no one posts one here, Ill take one myself.
Once everything is located, I plan to pull the jets/etc. individually and take pictures, hopefully being able to instruct people how to identify/read the markings, and show what goes where and how the pieces fit together.......
Just something that would just give someone more confidence with their carb, without/before buying a manual (something I would do if it wasnt hard to find locally).
Anyways, I will use this thread to compile pictures/info. Once the pictures have been made, and everybodies tips/tricks/jetting has been shared I will put it into a new thread hopefully covering everything to do with a weber sidedraft.
I ask that we take this step by step and dont get ahead of ourselves, working our way up from Jet locations, to initial setup, to getting the car running, tuning, and then little tips/tricks and troubleshooting.
I believe that once its finished, a very helpfull thread can be made and the future weber carb owners will have a good place to start.
Thanks in advance, I cant wait to see what we come up with!!!!!
Old May 15, 2007 | 06:35 PM
Sgt.Stinkfist's Avatar
premix, for f's sake
weber w/ jet cover removed. the 2 top screws are the main jet holders, 2 bottom screws are the idle jet holders
heres the main jet assembly, from top to bottom :jet holder, air bleed, emulsion tube, main jet
this is the idle jet assembly. top half is the idle jet holder, bottom half is the idle jet
hope this helps.
Old May 15, 2007 | 08:11 PM
1badFB's Avatar
GSSL-SE
Ok, Im back... Took some pics so Ill post em up and we can begin:
Just for fun heres what we are working on:
Once the top cover is removed, here is what you see. I have numbered everything (including adjustments) for completeness.
Heres a breakdown of whats in there:
Old May 15, 2007 | 08:18 PM
1badFB's Avatar
GSSL-SE
#1 - Idle jet
#2- Main jet assembly
A-air bleed
B-emulsion tube
C-main jet
#3 - ?
#4 - Cap over accelerator pump weight+valve
#5 - ?
#6 - ?
#7 - ?
#8 - Idle mixture screw
#9 - Cap / Pump Jet
#10 - Air bypass screw
#11 - Idle speed screw
Old May 15, 2007 | 08:38 PM
#3 - acc. pump inlet valve
#5 - starter jet & holder
#6 - progression hole inspecton screw
#7 - progression hole cover
Jeff20B
73
Sep 16, 2018 07:16 PM
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
