PFSupercars GT42R makes 711RWHP 566torque!
Old Mar 18, 2007 | 07:58 PM
  #76
ErnieT's Avatar
Living life 9 seconds at a time
Originally Posted by kabooski
not really most people switch to external pumps when making that kinda power
I'm debating what fuel system to go with myself and the idea of running a external
(which everyone said I would have to , does not agree with me ..Your Fuel setup gives me hope
1 more question if you don't mind
what where your injector duty cycles ? %
80-85%
Old Mar 18, 2007 | 07:59 PM
  #77
ErnieT's Avatar
Originally Posted by crispeed
Was boost dropping at high rpms?
Yep. Went from 35 down to about 30
Old Mar 18, 2007 | 10:06 PM
  #78
crispeed's Avatar
'Tuna'
What boost controller and W/G spring?
Old Mar 19, 2007 | 01:28 AM
  #79
Boostn7's Avatar
The 76mm will hold the boost though.
Ernie, anyway to confirm which GT42R you have?
Could be:
-70.3mm inducer w/ 94mm exducer or 74.3mm inducer w/102mm exducer.
Judging by some old pics you posted it looks like a 74mm inducer......but hard to confirm.
JD
Old Mar 19, 2007 | 02:29 AM
  #80
crispeed's Avatar
'Tuna'
Could be:
JD
John
I believe Ernie said it was the 70 mm inducer version.
Old Mar 19, 2007 | 05:38 AM
  #81
T04Eneedy's Avatar
adiabaticly inefficient
i believe on compressor wheels they always round it up if its larger than a whole number(like 70.3 rounds to 71mm).
Old Mar 19, 2007 | 06:29 AM
  #82
ErnieT's Avatar
New AVCR and 20lb spring on the Tial 44mm
Old Mar 19, 2007 | 06:30 AM
  #83
ErnieT's Avatar
Could be:
JD
Sean @ Aspec will be able to shed some light on exactly the measurments you want.
Old Mar 19, 2007 | 09:27 AM
  #84
Japan2LA's Avatar
I just read thru the threrad again and have a question.. You already said no water/meth but what about Nitrous? A friend of mine is convinced that nitrous was used (even in a small amount) to help motivate your turbo...
Old Mar 19, 2007 | 10:18 AM
  #85
Zero R's Avatar
Just in time to die
I was just waiting for your permission
It is at the moment a 4202R with a 1.01 T6. I say at the moment because we all know Mr.T wants more
-S-
Old Mar 19, 2007 | 10:28 AM
  #86
Zero R's Avatar
Just in time to die
There should be no reason to need nitrous on his setup. Wether he is or not I don't know but that turbo when setup correctly will run around the response he is seeing. Depending on the compressor used along with turbine A/r and a few other things you will see pretty decent response ranging anywhere from 3900-4500RPM. I believe he is seeing pretty close to that.
-S-
Old Mar 19, 2007 | 11:00 AM
  #87
matty's Avatar
nice numbers.
any street driving vids yet?
Old Mar 19, 2007 | 11:04 AM
  #88
dhahlen's Avatar
FD Under Construction =P
Time to throw on a GT45r and break 800? Hehe, thats sick man. Gives me hope though, my insanely ported engine might break 650 on the KAI. Don't get me started, more money to throw into the FD to make it a 700hp car... damn you and making me want to do things I shouldn't!
It's nice though..
Grats
Old Mar 19, 2007 | 11:22 AM
  #89
ErnieT's Avatar
Your friend was wrong. If I used Nitrious, my torque would be even higher.
Old Mar 19, 2007 | 12:23 PM
  #90
Japan2LA's Avatar
Ok, I will pass it on to him....
Old Mar 19, 2007 | 01:06 PM
  #91
gt40byu's Avatar
con grats
Old Mar 19, 2007 | 01:39 PM
  #92
Boostn7's Avatar
-S-
I figured :-) ...... a 74.3mm inducer w/102mm exducer.
Thanks
JD
Old Mar 19, 2007 | 02:26 PM
  #93
T04Eneedy's Avatar
whats the compressor inducer limit in the class your running ernie?
Old Mar 19, 2007 | 05:27 PM
  #94
ErnieT's Avatar
76mm
Old Mar 20, 2007 | 12:21 PM
  #95
gt40byu's Avatar
what do you hope 2 c for times with the new set up?
Old Mar 20, 2007 | 04:56 PM
  #96
ErnieT's Avatar
9's are the goal.
Old Mar 20, 2007 | 08:55 PM
  #97
Musclefella's Avatar
Talking
Congrads man, awesome car.
Make some vids so the rest of us can enjoy to
Old Mar 20, 2007 | 11:09 PM
  #98
Gorilla RE's Avatar
GorillaRaceEngineering.co
Talking
9's are the goal.
9's?.......try high 8's!!!
Old Mar 21, 2007 | 07:28 AM
  #99
dhahlen's Avatar
I agree, you can do 9's if you're a decent driver at 600hp. 711, that would make you an 8 granted you can keep traction! =)
Old Mar 21, 2007 | 10:23 AM
  #100
Viking War Hammer's Avatar
*** Bless The USA
It sounds easy doesn't it. Well, it's not.
