85 SE radiator resurrection
Old May 14, 2017 | 08:02 PM
  #126
tool and die guy's Avatar
Enlightenment
I mentioned enlightenment in the very beginning of this thread. Let me count the ways: I've learned what igniters are and how they work. Learned about trailing and leading spark plugs. Learned the car will actually run just on trailing. Learned how not to use a ratchet on spark plugs. Learned rtv for gaskets. Learned tapping a given housing sideways to break and old gasket free. Learned to check the mounts on my oil cooler for droppage that could rub and compromise. Learned a lot of stuff needs to me removed to take out a simple radiator on my rx7. Learned to reinstall new foam under new radiator install... it has a purpose. Learned what tstat to stay away from and which temperature to buy a tstat for my car/climate. Learned it's nice to have smaller hands ( don't even go there, it's not true!!!) learned i might as well do some cosmetic improvements while all this stuff is off the car now. Learned to take my time and look at things from different angles- sometimes there's a better way just looking at it longer. Learned a 220 pc tool kit doesn't come with any extensions(!!) learned that so far Mazda designed a pretty userfriendly car to work on... I'm still learning
Old May 14, 2017 | 08:04 PM
  #127
Originally Posted by GSLSEforme
Paul,wrestling with this phone...composed a reply to your pm,don't know what happened. Will get back to you on desktop when get home sometime tomorrow.8
no problem!!
Old May 14, 2017 | 08:21 PM
  #128
Evans coolant
ok boys here's a big question. Had anyone heard of Evans waterless coolant? Saw first on J Leno Garage. I'm intrigued but realize I'm Rotary everything else is not. But it might make sense. After all it's a closed system. I'm deleting the heat core, reconditioning the radiator. It'll be a new system. Would Evans be a good alternative? I already got a reply from Evans . Said they have used in in Rotary with much success just suggested new core,radiator and hoses. Well that's me!! If you get a chance check it out tell me what you think
Old May 14, 2017 | 08:28 PM
  #129
wankel=awesome's Avatar
carb whisperer
I saw your SE there too! I wish I would have known what issues you were having. I had the tools, new connections, shrink tube, etc. I also had an upper/lower rad hose at my cabin, but it was for 12A. Maybe we could have made it work?
I was parked just 1 car ahead of you at the Dam. In your pictures I had already left, but I found this one that proves it!
The whole time I was there I was rolling with friends. Mostly RX8 folks. I missed out on a lot of the 1st Gen stuff sadly.
I may have talked to you a little bit, but I can't recall. So many new people I met down there lol.
I had to make a long drive as well, 13 hours back up the PA! Luckily we had no issues.
Old May 14, 2017 | 08:35 PM
  #130
hey there wankel A!! I saw yours. Didn't you get 1st in first gen? long story but I had this wide body 1 1/2 years ago. Couldn't keep it.
Old May 14, 2017 | 09:22 PM
  #131
Back to main topic.. water pump. I see there's two gaskets at $23 and change at mazdatrix. I can assume A. I need them. (?) B. They don't come with water pump(?)
Old May 15, 2017 | 04:26 AM
  #132
carb whisperer
I'm pretty sure that widebody you have pictured is now mine...
mine looked exactly like that when i got it, including the 1/4 turn fasteners...
Old May 15, 2017 | 07:23 AM
  #133
you gotta be Kidding me!! Did you get it from a guy in Barberton Ohio? I'm pretty sure that's mine. So that's the one parked in front of mine at the Damn?
Old May 15, 2017 | 07:34 AM
  #134
that had to be mine. That was my second 7 in 1986ish. I drive it till it had 82k on it. Sold it in 92 to an employee who drove it 6k and parked it for a few years. A friend of his traded him a ford truck and some cash. He drive it 400 miles and parked it in his garage for 15 years. I hired him and we were best friends and he worked for me 16 years. Started a project car but a bitter divorce dropped his enthusiasm. I can tell you more about if you want. It was T boned once but I spent big money getting her right. That's yours on the left circa 1988 next to my gsl
Old May 15, 2017 | 07:45 AM
  #135
carb whisperer
That's the same car.
lol small world buddy. I got it from another member in ohio...
I bet you never expected it to show up just one spot from yours at DGRR!
Old May 15, 2017 | 08:00 AM
  #136
this is toooooo fooking amazing. You finished it!!! AND!!! You finished it exactly how I wanted it!! Drove my daughters all over the place when they were babies. This is just tooo cool.!!! I beat a Porsche 944 turbo S with that sucker once. The engine trans went to Mike simonov in GA. Much of the suspension is now on mine today!!!
Old May 15, 2017 | 08:10 AM
  #137
is your name Curtis?
  #138
carb whisperer
All the running gear on mine is from my gslse donor, except the engine. It's an aging pineapple engine with lapped side housings (yuck). It smokes on decel because of it. Great compression, and it tore up US129, but it's about to get a goopy semi p port.
totally incredible. Great thread! Lol
My name is Derek btw, but I might know the Curtis you mentioned lol
Old May 15, 2017 | 09:13 AM
  #139
Well it ended up in the right place. The p port will make it sing and brap with the best of em!! These are the kind of rotary stories that make it all cool and satisfying. I'm just glad it got finished. The wide body kit was Air Buni brand jfyi. No longer available so don't smash it up!!
Old May 15, 2017 | 09:40 AM
  #140
GSLSEforme's Avatar
ancient wizard...
This is good stuff,has some limitations. Would recommend a 50/50 fill of good quality coolant for first fill,make sure no leaks,road test etc and if all good switch it over later if after a time everything is fine. Cost is a little high in event of a mistake/leak to replace.
Old May 15, 2017 | 09:49 AM
  #141
GSLSEforme's Avatar
ancient wizard...
Mike I read the whole thing. So you still didn't have your car ready for DGRR. You've waited a long time for that much damage to be repaired.
Have had a lot going on in last year,not all car related. Did lose a lot of time dealing with insurance co. Lost my spot in line at my friends' shop because of it. His shop is busy,he does a lot of body/paint repairs on high end cars for several local dealerships as well as restorations. Have not found anyone better & trust him to do all paintwork on motorcycles i restore. Have waited to get back in rotation for my car for awhile as i don't want him to feel pressure to rush-he knows what i want,we've worked together a long time.
Old May 15, 2017 | 10:22 AM
  #142
good advice. That's why you're a real mechanic and I'm learning to be one. I'm just a lowly tool and die maker!! Lol
the part Evans talks about no steam seems to make sense. Steam means hotter, has oxygen which equals oxidation. Imho that equates to water jackets eventually failing. Took off the old hoses and I'm pretty sure they were original. There's rust deposits around the spouts where the hoses came off. The tstat cover is particularly rusty. I'm going to emery it lightly then clean further w scotch brite. I'll paint outside with high temp and leave interior alone. I know I could get a new one but think I can salvage the original.
Old May 15, 2017 | 10:25 AM
  #143
a good body man is always worth the wait. Never worth rushing them either.
Old May 15, 2017 | 03:01 PM
  #144
GSLSEforme's Avatar
ancient wizard...
oh that's real funny.. you CANT bring rx7 and get to drive the dragon in a Buick.. I BRING rx7 and never make it to the dragon!! I have to ask..? What is the non stock coil pack you got going there? Looks like one coil is a double and a single.(?) funny coil story.. two years ago Kenny discovered that years earlier the wrong coil was installed on mine. A standard coil if you will.. he researched and figured out that the proper coil for the SE changes from 9 volts to 12 volts where as the one on my car did not. Also a standard coil isn't made to handle the highest revs..I drove it that way for years. The difference was instantly noticeable.
Not certain what you're saying about your incorrect coil... what you're looking at is my version of DFI ignition,2nd gen coil fires leading,aftermarket TFI coil fires trailing thru leading ignition plug wire positions in distributor cap. Several reasons for this version, 1st don't want to drill or cut any holes in car to make mods that i want as if i ever want to return car to all original,don't want to have any extra holes as evidence something other than stock was there previously. Every modification done to the car is with this in mind. The bracket that you see that holds the coils & modules on back side you can't see when installed,i fabricated from aluminum,drilled,tapped and mounted everything you see to it bolts to same threaded inserts in left fenderwell that held oe ignition coil bracket. 2nd, though individual coils is best way to go,underhood area is at a premium on an SE when one wants to keep a/c and all else original AND don't want to drill/cut any more holes in car so.. after a lot of experimenting and testing of coils and modules i decided on what you see here. Ran well before with oe ignition,runs better now,seems to pull harder everywhere in rev range and definitely has more torque down low. Exhaust note is different too. Having removed all emission controls,this mod has cleared up exhaust smell also and while haven't had chance to put any real amount of miles on it,seems to be a tick better on fuel consumption.
Attached Thumbnails 85 SE radiator resurrection-img_1513.jpg   85 SE radiator resurrection-img_1515.jpg   85 SE radiator resurrection-img_1617.jpg   85 SE radiator resurrection-img_1619.jpg   85 SE radiator resurrection-img_1620.jpg
Old May 15, 2017 | 03:53 PM
  #145
THAT is a very interesting and unique mod. I've been all over the place in these forums I've yet to see that one. I'll have to check that one out more later. I still have air pump and all the pollution stuff. I'll definitely look harder at this one when I get passed all the stuff I'm doing now.
Old May 15, 2017 | 04:15 PM
  #146
GSLSEforme's Avatar
ancient wizard...
Search DLIDFIS, lots of info will come up t_g farrel has a version of this in his car called TFIDFIS and sometime in recent past has changed it to more like what i have. Look under his screen name,its there,click on it will take you to thread he started to document it all.
Old May 15, 2017 | 05:00 PM
  #147
dlidfis.. I've seen that mentioned but didn't pay much attention. I thought it only referred to removal of the rats nest.
Old May 15, 2017 | 05:22 PM
  #148
GSLSEforme's Avatar
ancient wizard...
Mazda oe pump does NOT come with gasket. Mazdatrix part# for pump 15-130C-N232 & only one gasket #15-1160-N2Y0 needed.
Old May 16, 2017 | 01:33 PM
  #149
Currently existing stock w air pump. We talked about this for an air pump delete and optional double pulley on water pump(?) which would be adjusted via the alternator adjustable bracket(?)
Old May 16, 2017 | 01:46 PM
  #150
GSLSEforme's Avatar
ancient wizard...
Double pulley on alternator,2nd belt to be installed will run in same pulleys vacated by air pump belt
Attached Thumbnails 85 SE radiator resurrection-4505-mms-1487900457901-attachment1-0209161601a.jpg   85 SE radiator resurrection-img_1629.jpg   85 SE radiator resurrection-img_1630.jpg   85 SE radiator resurrection-img_1631.jpg   85 SE radiator resurrection-img_1632.jpg
