Opinions: Dual Wastegate vs Single
Old Mar 5, 2017 | 07:34 PM
Monsterbox's Avatar
Mazzei Formula
Old Mar 5, 2017 | 08:02 PM
spintriangles's Avatar
Tenured Member: 5 Years
Does anyone run a boost controller with dual wastegstes
Old Mar 6, 2017 | 11:15 AM
I ran a manual boost controller on mine.
You just daisy chain the wastegates.
Old Mar 6, 2017 | 05:18 PM
KNONFS's Avatar
B O R I C U A
I am running a fully divided manifold with independent wastegates (one per runner). My manifold is similar to the one posted above, except that the runners are just a tad longer, and the turbo is pushed forward.
I have used the ECU open loop boost controller successfully.
The top port of each wastegate goes to a T, same with the lower port on the wastgates, they go to another T. Each T goes to its designated port on the solenoid
Old Mar 6, 2017 | 06:12 PM
Having problems with my set up since day one. It is bit and miss when the wastegates work correctly together. I am going to check It tomorrow.
Old Mar 6, 2017 | 08:30 PM
Red94fd's Avatar
here is my controller set to 13 psi.
Bottom port of the wastegates "T" to port 1 of the solenoid "T" to compressor boost source. The top port of the waste gates "T" to port 2 on the controller solenoid.
It works for me..
Old Mar 6, 2017 | 08:40 PM
Red94fd's Avatar
Old Mar 7, 2017 | 12:49 PM
Hmm. Mine is set up like this
Old Mar 7, 2017 | 12:50 PM
Old Mar 7, 2017 | 12:52 PM
Old Mar 7, 2017 | 01:57 PM
ZE Power MX6's Avatar
Boilermakers!
The front port is for actuator type wastegate (stock twins), you need to use the side port for external gate.
Old Mar 7, 2017 | 05:25 PM
Red94fd's Avatar
Greddy electronic boost controller directions are confusing, it says the por 2 should be vented. I did some reading and I changed it around how is in the little graph.
Old Mar 7, 2017 | 05:26 PM
Red94fd's Avatar
Sorry, meant port 1.
Old Mar 7, 2017 | 07:14 PM
Ok. Got it so I should change the middle port to the side port. I tighten up some stuff and it seem to work a lot better. 1 and second gear saw so much boost though that the boost controller sent me into fuel cut. I'm third gear I held boost at 15 psi. Tomorrow I am going to switch it to the side port to see she runs. Thanks man. I believe the way the hoses are ran are also wrong.
Shainiac
Jul 17, 2019 02:20 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
RxglassJAw
NE RX-7 Forum
Sep 10, 2015 07:35 PM
