S4 Primary Fuel Rail On S5?
Old Feb 4, 2017 | 01:40 PM
bwrx7's Avatar
Certified RoTard
I've read a couple of threads where people have swapped on S5 rails on S5 T2's but none of them really answered my question, Rotary Evolution told me that if I replace the S5 rail with an S4 and do the banjo bolt mod it will most definatley fix my fuel leak. I just primed the pump and its for sure the primary rail's FPD.
So just to make sure, I can use a NA S4 Primary rails on a NA S5???
Old Feb 4, 2017 | 02:22 PM
Yes, just make sure you have that plastic insulator between the engine and the fuel rail.
I used S4 TII primary fuel rail on my S5 TII engine.
Old Feb 4, 2017 | 02:25 PM
bwrx7's Avatar
Certified RoTard
Thank you! Too bad Mazdatrix doesn't sell the S4 rail... Gotta find one in classifieds now.
Old Feb 7, 2017 | 09:24 AM
bwrx7's Avatar
Certified RoTard
Reviving this real quick...
Was told I'd need an S4 UIM & LIM because the S4 primary rail wont clear the S5's UIM...
Old Feb 7, 2017 | 10:08 AM
RotaryEvolution's Avatar
Sharp Claws
i've heard people say it won't clear but i haven't actually run into that issue yet.
ill double check it when i get to the shop, since i have all the parts you'd need.
Old Feb 7, 2017 | 10:19 AM
Oh, maybe.
I used S4 TII fuel rail with S5 TII LIM and FD S6 UIM.
I have to say-
if you take off the pulsation damper and do AN lines on a S4 primary fuel rail, it is hard to see how it won't clear. I mean, its just the difference in thickness between cast aluminum (S4) and pressed steel (S5). Since the UIM is also cast aluminum some grindy grind should suffice if the S4 primary rail touches it.
You can also get an aftermarket S4 style primary fuel rail for ~ $130 if you can't find a Mazda one. Still need the plastic insulator.
Ebay-
Old Feb 7, 2017 | 10:26 AM
bwrx7's Avatar
Certified RoTard
Thank you so much man!! Hopefully I'll get this all sorted out...just need to keep reading!
Again thanks for all your help!
-Ben
Sharp Claws
pretty sure it was the PD that would hit, since it is deleted it is not an issue using the aluminum non turbo rail.
Old Feb 7, 2017 | 10:27 AM
bwrx7's Avatar
Certified RoTard
I'm gonna buy a Primary off eBay and test it out... if not I'll find an intake in the classifieds.
Thanks for the info!
Old Feb 7, 2017 | 10:29 AM
Sharp Claws
don't switch intakes, you'd need to replace EVERYTHING on the intake and downgrade to an S4, which creates more problems than it solves.
Old Feb 7, 2017 | 10:31 AM
bwrx7's Avatar
Certified RoTard
Oh...that makes sense
If none of it works I'll just get an S5 rail off mazdatrix
Old Feb 7, 2017 | 10:32 AM
Sharp Claws
or you could let me help you, since this is how i make a living... and it's totally awesome seeing other people get the sales. not that i guess i'm not used to it by now.
Old Feb 7, 2017 | 10:34 AM
bwrx7's Avatar
Certified RoTard
I'll take any help I can get hahah
This is my first rotary, I get how they work but the systems that mazda added go over my head...
Old Feb 7, 2017 | 10:40 AM
Banzai-Racing's Avatar
Rotary Specialists
S4 rails on S5 engine
Old Feb 7, 2017 | 10:41 AM
bwrx7's Avatar
Certified RoTard
damnit that's so clean... so it would clear an S5 uim with the AN line returns?
Old Feb 7, 2017 | 10:51 AM
Sharp Claws
thats a turbo engine
there is some discrepancies with the non turbo UIM fitments but for the most part it was the S4 EGR from memory that wouldn't allow a S5 UIM to go onto an early block without some grinding or a blockoff plate.
Old Feb 7, 2017 | 11:08 AM
bwrx7's Avatar
Certified RoTard
yeah I see that now..
The aluminium rail doesn't look that much bigger like you said. Hopefully its just the FPD that doesn't clear.
Old Feb 7, 2017 | 11:15 AM
Sharp Claws
the pulsation dampener is also on the opposite side of the rail on the non turbo but yes, eliminating it opens a bit more space.
but i'll double check and give you a better idea tonight after i can put it all together to see any potential fitment issues, though i don't recall there even being any in this case.
Old Feb 7, 2017 | 12:04 PM
bwrx7's Avatar
Certified RoTard
I really appreciate this man! Thank you so much.
Old Feb 7, 2017 | 01:27 PM
Rotary Specialists
I didn't see that you were trying this on an N/A, still should not be an issue.
Here is an S4 TII rail next to a S5 N/A, looked around for a S4 N/A but no luck.
Old Feb 7, 2017 | 01:29 PM
bwrx7's Avatar
Certified RoTard
Thanks guys! I really do appreciate the help
Old Feb 7, 2017 | 08:37 PM
Sharp Claws
the S4 primary rail will not fit under the S5 UIM with the PD on it(the PD itself is too large compared to the smaller S5 stamped one), i do have one already modified with a PD delete that fits just fine under the S5 UIM.
i verified it by mocking up a S4 rail onto an S5 block with S5 manifold.
Old Feb 7, 2017 | 08:40 PM
bwrx7's Avatar
Certified RoTard
Awesome man! This helps so much! I really appreciate you testing it out for me!!!
Old Feb 7, 2017 | 08:42 PM
Sharp Claws
no problem
Old Feb 17, 2017 | 07:50 AM
bwrx7's Avatar
Certified RoTard
Thread Update!
Rail from RotaryEvolution got here! Super clean and super fast shipping. +1000 to him.
Got the old rail of annnnd! Broken injector caps and fuel rail spacer
The new parts should get here today though
Attached Thumbnails S4 Primary Fuel Rail On S5?-photo429.jpg   S4 Primary Fuel Rail On S5?-photo384.jpg   S4 Primary Fuel Rail On S5?-photo659.jpg   S4 Primary Fuel Rail On S5?-photo624.jpg
