Semi Peripheral Port with Primary's Only?
Old Oct 14, 2016 | 12:26 PM
fritts's Avatar
Mad Man
Wondering if any one has heard of a semi peripheral port only using the primaries? Thinking about making a port in between a full and semi port to compensate for the lack of secondary port. Looking at using a slide throttle for the peripheral ports but combining with the primary to 1 throttlebody. Transition I'm assuming will be tricky but most likely will control via the ecu table.
Old Oct 14, 2016 | 01:52 PM
Yes, I saw this set-up in old Hyper-Revs I think.
The p-ports were bigger than the usual little semi p-port.
I will see what I can dig back up.
Old Oct 14, 2016 | 01:57 PM
The other way to do the same thing would be to fill in the stock 2ndary port and make a waterjacket J-bridge port (a p-port that uses stock runner and enters at the side of the rotor housing instead of the center like a p-port).
This style could use stock intake set-up with dual throttle to do exactly what you want easily.
Old Oct 15, 2016 | 05:31 PM
Got home and World Time Attack was on and I forgot all about this.
I didn't have the pic in my Hyper-Revs since mine are ~2001 and the semi p-port circuit cars popularity came about a bit later.
Here is a pic of the intake manifold/rotor housings in question though-
Old Oct 16, 2016 | 01:09 PM
i have an Rx7 magazine with two NA FD setups in it. well three.
the first is an AR-F car, its running the 9.7 rotors and a bridge port, plus a hundred shot of nitrous. no HP numbers, but its probably 210-220rwhp without the nitrous.
the second is an earlier version of the housings and manifold blueT11 posted. this one has a small PP and uses all four side ports. again no HP quote, but
setup 3 is setup 2 with a turbo, and is over 800ps.
also there was the scoot FD, it used the same or similar semi PP housings and it was ~700ps@20 psi.
Old Nov 15, 2016 | 03:01 AM
13BT_RX3's Avatar
The General RE
Have you seen the 4 rotor on CLR Motorsports website?
It appears to have side port primaries and very high peripheral port secondaries.
Link to other pics:
Full Race 4R. TURBO
There is also a video series on YouTube documenting the build of a 13B with a similar, but more complicated setup. Here's the link to video 1 if you haven't seen it.
I wonder if the higher port location would provide less overlap and have better idle quality compared to the normal semi p-port location.
Old Nov 15, 2016 | 06:11 AM
fritts's Avatar
Mad Man
When someone starts out using an endmill in a drill chuck it makes me wonder about how advanced it really could be....
in ref to the video
Old Nov 15, 2016 | 09:06 AM
13BT_RX3's Avatar
The General RE
in ref to the video
Well, that endmill chatter scene as the introduction probably wasn't the best production choice, but lf you skip to about the 16 minute mark there's a good open motor view to see the p-port location. The 4 rotor version seems like a more refined iteration of the concept. Both appear to share the same approximate p port location. This port location should provide the same benefits of more flow area and intake duration as a semi p port, but looks like it should have less exhaust/intake overlap. Excessive overlap seems to be the root cause of p port drivability issues, so there may be something to this idea. I'd like to see video of one of these motors running. I also wonder if someone would be able to estimate the port timing from the pictures or video.
Old Nov 15, 2016 | 11:56 AM
fritts's Avatar
Mad Man
Was looking at doing an oval p port higher up in the housing, to help with overlap as well. Think the angle he's pushing is extreme though. I'm really skeptical of him seeing the results he's talking about in the video's.
FC3Sdriift
General Rotary Tech Support
Oct 21, 2016 01:33 PM
