Pictures of FC wheel fitment with specs... ***Picts-n-Specs ONLY***
Old Oct 19, 2014 | 05:18 PM
  #926
andycivic's Avatar
Stick & Slide #007
GA
Specs are 17x9.5 +11 17x10.5 +11 work rezax
Old Oct 19, 2014 | 05:52 PM
  #927
andycivic's Avatar
Stick & Slide #007
GA
<a href="http://s177.photobucket.com/user/andy-civic/media/Mobile%20Uploads/2014-10/18AF8F51-312B-4F8E-A83E-BC1A85037487_zpssv4l0elt.jpg.html" target="_blank"><img src="http://i177.photobucket.com/albums/w237/andy-civic/Mobile%20Uploads/2014-10/18AF8F51-312B-4F8E-A83E-BC1A85037487_zpssv4l0elt.jpg" border="0" alt=" photo 18AF8F51-312B-4F8E-A83E-BC1A85037487_zpssv4l0elt.jpg"/></a>
Old Sep 23, 2015 | 12:10 AM
  #928
meximan's Avatar
bringing this thread back from the dead...I have the same exact specs as this car..what tire size did you run and could you have ran larger?
Originally Posted by labuffness
Couple shots of my pile. Wheels are 17x8.5 25 and 17x10 15. They are for sale someone buy them.
Old Sep 30, 2015 | 11:22 AM
  #929
FC3S Timmy's Avatar
ReTripleOG
front fits perfectly with a little camber but i had to raise it to this height to be able to park in my backyard.
17x9.5 +18 215 45 Front 17x10 +18 225 45 rear
Old Oct 1, 2015 | 01:43 AM
  #930
jdmbrendan's Avatar
Some functional fitment on my FC3S Turbo II
F: 17 x 9.0J +22 / 235/40 Toyo R888s
R: 17 x 10J +18 / 255/40 Toyo R888s
Old Oct 1, 2015 | 11:50 AM
  #931
FC3S Timmy's Avatar
ReTripleOG
damn i shouldve did 9 in the front. Nice car
Old Oct 1, 2015 | 01:14 PM
  #932
minusdarkslide's Avatar
AEZ wheels 17x8.5 +13 square
Old Oct 1, 2015 | 08:11 PM
  #933
mxrider914's Avatar
16x8 and 16x9 +33 Work Equip 05
5mm spacer up front
Old Nov 22, 2015 | 04:23 PM
  #934
Jayride's Avatar
Is this with stock fenders?
Old Dec 17, 2015 | 01:47 PM
  #935
RadioX7's Avatar
X MARKS THE SPOT
Old Dec 17, 2015 | 07:50 PM
  #936
s70simon's Avatar
Banned
Here is me trying on Supra TT wheels. Size is 17x9.5 with 225/50 "stretched". Currently have FD wheels with same tire size and a 25mm spacer in front and 50mm in the rear. Just ordered new spacers for the front with correct HC diameter. Will upload more pics when they come in. BTW anyone else seen TT wheels on FC? Just want to get a taste of how they look. I plan on plasti dipping them white and probably doing wide over fenders.
Old Jan 12, 2016 | 10:31 PM
  #937
2jzfc's Avatar
LegacyCore
16x7.5 +40
Old Apr 1, 2016 | 10:27 PM
  #938
Eric Wolfe's Avatar
wolfman
Japanese ARE wheels
Old Apr 3, 2016 | 02:17 AM
  #939
canyontougeFC3S's Avatar
Enkei RPF1 (F) 17x10 +18 5x114.3
BFGoodrich T/A G-Force KDW (F) 255/40/17
Circuit Sports +15mm Hubcentric Spacers
Enkei RPF1 (R) 18x10.5 +15 5x114.3
BFGoodrich T/A G-Force KDW (R) 275/35/18
WheelMate 1.5" Hubcentric Adaptors
Old Apr 13, 2016 | 06:41 AM
  #940
Party Cat's Avatar
G35 rears on the front 17x8 +33 235/40
Adan VS6 on the rear 17x7 +30 225/45
Old Jul 14, 2016 | 03:54 PM
  #941
Johnny Kuro's Avatar
17x9 +25 all around. 215/45/17. stock ride height with kyb agx's...for now. should be a perfect fit on coils
Old Aug 13, 2016 | 07:58 PM
  #942
ILoveJDM's Avatar
SSS-TUTUTU
attempting to save this page...
18x9.5 +11 bbk face for r32 gtr brakes
18x9.5 +10 max lip face
Old Aug 14, 2016 | 11:19 AM
  #943
GeenIdee's Avatar
Is there a specific reason you went for 17" front and 18's in the rear?
Old Aug 26, 2016 | 11:51 AM
  #944
infernosg's Avatar
Enkei RPF-1 17x9 +22 w/ 255/40R17 Dunlop Direzza ZII on all four corners. Shine Auto front fenders and pulled rear fenders.
Old Aug 26, 2016 | 12:30 PM
  #945
LargeOrangeFont's Avatar
Fistful of steel
Any details on that lexan rear hatch?
Old Aug 26, 2016 | 02:00 PM
  #946
infernosg's Avatar
Don't want to derail the thread too much but it's an Optic Armor 1/8" window on the stock frame with two 1/8" aluminum straps. I used black vinyl wrap around the edges for a stock look. The panel comes pre-moulded and over-sized so it had to be trimmed along the edges. It's supposed to have a protective coating but time will tell. I'd estimate the whole assembly is around 20 lb. It'll sucker punch you in the jaw with the stock supports if you aren't paying attention when opening it.
Old Aug 26, 2016 | 04:58 PM
  #947
Fistful of steel
Thanks very much! I have been looking for one since they stopped being offered by Percy's.
Old Sep 16, 2016 | 12:52 PM
  #948
caeya's Avatar
Unbereevable
New setup:
F: Work T7R 18x9.5-3(15mm spacer) 215/40/18 with a Foresight 30mm wide fender and -9 degrees of camber (PBM flca)
R: Work T7R 18x9.5-3(15mm spacer) 215/45/18
with Foresight 35mm wide fender and -3 degrees of camber
Attached Thumbnails Pictures of FC wheel fitment with specs... ***Picts-n-Specs ONLY***-image-2205149696.jpg   Pictures of FC wheel fitment with specs... ***Picts-n-Specs ONLY***-image-2411723375.jpg
Old Sep 24, 2016 | 02:01 PM
  #949
marty_martyrdom's Avatar
Which of these sizes be ok on a stock body fc vert? And which would need some modification or spacers/fender roll?
15x8 +6
15x8 -19
16x8 0
Thanks!
Old Sep 25, 2016 | 01:23 PM
  #950
caeya's Avatar
Unbereevable
Originally Posted by marty_martyrdom
Which of these sizes be ok on a stock body fc vert? And which would need some modification or spacers/fender roll? 15x8 +6 15x8 -19 16x8 0 Thanks!
15x8 +6 and 16x8 0 would fit fine on stock fenders. 15x8 -19 would need the fender lip rolled and possibly a bit of a pull.
This is my old car with 16x8 0 on stock fenders for reference
Attached Thumbnails Pictures of FC wheel fitment with specs... ***Picts-n-Specs ONLY***-image-1962664906.jpg
