Post pics of your engine bay
Old Aug 9, 2016 | 12:07 AM
  #1151
Hygoog's Avatar
Yours look pretty clean compared to some of the other ones I've seen. It just needs a little touch up. That cooling panel look sick. I want to get one too eventually. When I first got mine it was pretty dirty. The previous owner didn't take good care of it. It came a long way to look like the way it is today. Too bad it's NA. Since I don't have the funds to make power yet, I'm just focusing on making it clean and reliable.
Old Aug 9, 2016 | 04:38 PM
  #1152
Akaviri's Avatar
Thank you. I cleaned it up quite a bit from the previous owner, but I didn't go too in-depth. If you get a cooling panel be sure to get one that has a vent for the intake tube.
I didn't know you could pressure wash an engine bay, nor have I heard of steam cleaning one. Did you do that yourself or take it somewhere to get done?
Old Aug 9, 2016 | 05:02 PM
  #1153
Hygoog's Avatar
Sweet ok. Yes you can lol just be careful when you do. Cover up your sensors and electrical stuff. I covered up my sensors, battery, and alternator. Just spray lightly. Dont soak it completely. Make sure the car is cold when you start cleaning. I used a pressure washer and steam cleaner from harbor frieght. It gets the job done for the price.
Old Aug 12, 2016 | 09:10 PM
  #1154
Pietro931's Avatar
89 Turbo II
All Stock
Attached Thumbnails Post pics of your engine bay-20160508_074917.jpg   Post pics of your engine bay-20160508_074843.jpg   Post pics of your engine bay-20160508_074901.jpg
Old Aug 12, 2016 | 10:13 PM
  #1155
Hygoog's Avatar
Nice. A clean stock engine is hard to beat. I wished mine was turbo...sigh. You have a fc and fd! Ohhhh yeaa!
Old Aug 13, 2016 | 05:55 AM
  #1156
Pietro931's Avatar
Thanks. One of each and both red and black. FC 59k miles, FD 28k miles.
Old Aug 13, 2016 | 07:40 PM
  #1157
ILoveJDM's Avatar
SSS-TUTUTU
Old Aug 16, 2016 | 12:39 PM
  #1158
infernosg's Avatar
Work in progress...
Old Aug 27, 2016 | 01:44 PM
  #1159
ben.farnath's Avatar
Current situation. Deloomed. Only wired left are power wire to insulated power stud for remote start and from the oil level and pressure senders. Next is painting motor and finish the ecu wire up. Tidy up the brake lines from abs delete then piece it all back together.
Old Aug 27, 2016 | 09:41 PM
  #1160
infernosg's Avatar
Originally Posted by ben.farnath
Hopefully it'll run as good as it looks! I love the Gilmer setup. It's too bad there's not a compatible FFE trigger kit otherwise I'd be running them as well.
Old Aug 28, 2016 | 01:49 AM
  #1161
What's the purpose/benefit of the ffe trigger setup over factory cas? I had never seen it before.
The Gilmer kit was out of necessity at the time somehow managed to shear off two of the main crank pulley bolts and warped the pulley. Now I need a replacement matched pair stock pulley and hub to do timing for the microtech. Fml.
Old Aug 28, 2016 | 07:57 AM
  #1162
GuiltySoul's Avatar
Perfectly Broken
My stock na
Old Aug 28, 2016 | 07:27 PM
  #1163
infernosg's Avatar
It's a higher fidelity crank angle signal, which gives me more accurate and minute control over fuel and spark. Considering my rotating assembly is balanced for over 10,000 RPM and I have ceramic apex seals I didn't want to take any chances.
Old Aug 29, 2016 | 01:42 AM
  #1164
Well fair enough! 10000rpm-mmmm that'll be some aural ecstasy
Old Oct 13, 2016 | 04:59 PM
  #1165
joeylyrech's Avatar
87 SE WITH S5 T2 SWAP
PA px
my fc engine bay
Attached Thumbnails Post pics of your engine bay-20161006_124310.jpg   Post pics of your engine bay-20161006_124333.jpg   Post pics of your engine bay-image2.jpg
Old Oct 16, 2016 | 03:26 PM
  #1166
GeenIdee's Avatar
Old Oct 17, 2016 | 11:07 PM
  #1167
clokker's Avatar
Cake or Death?
Very artfully arranged, this one.
Old Oct 18, 2016 | 11:15 PM
  #1168
GuiltySoul's Avatar
Perfectly Broken
Lil update, installed a corksport intake, meant to fit s4 models but i modded it to work on s5
Old Oct 28, 2016 | 03:49 PM
  #1169
rookie117's Avatar
Old Oct 28, 2016 | 05:01 PM
  #1170
cib24's Avatar
Originally Posted by Pietro931
All Stock
Beautiful. Have you had the engine bay resprayed? Looks new from afar in the photos.
Old Oct 28, 2016 | 05:02 PM
  #1171
cib24's Avatar
Work in progress...
Lovely. Curious question. When you go to respray everything do you spray rust converter or stopper as a precaution before prepping and spraying a new coat of paint?
Old Nov 3, 2016 | 06:53 AM
  #1172
infernosg's Avatar
I had the car chemically stripped down to the bare metal before having it resprayed. The worst rust spots were cut out and replace/patched then the whole thing was primed and painted. I spent WAY too much on the body work for this car. Hopefully it'll be a long time before any new rust appears. I hate to think how much I'd have spent if I went with a "show quality" paint. It just goes to show how expensive proper body work is.
Old Nov 11, 2016 | 02:54 AM
  #1173
Sash91's Avatar
Originally Posted by rookie117
What fan shrouds are you guys using?
Old Nov 11, 2016 | 08:57 PM
  #1174
profc3s's Avatar
I'm loving all these clean engine bays! It's giving me great ideas for mine.
mazdaverx713b
48
Apr 21, 2016 06:45 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
