Fabrication Post your questions and projects on Fabrication of Interior or Exterior or custom audio and electronics here.
ffe trigger disc with side mount alternator
Old Sep 11, 2014 | 03:15 AM
Mr. Johnson's Avatar
I have a 95 fd and I have an side mount alt bracket on the car. I want to run the ffe trigger disc but im having some trouble with belt alignment and sensor placement not sure which kit to buy and if I need anything custom made. I have some ideas but just wanted to see wat u guys thought.
Heres the alt on my car
Heres the alignment issue
Heres the the 2 disc setups I have to choice from this one is for the fd
This is the one for an fc
Im trying to not have to modify the alt bracket. But any ideas would be awsome. Thanx joey
Old Oct 13, 2014 | 12:36 PM
RedDream's Avatar
If your electrical wires reach maybe put some threaded spacers on the alternator with longer bolts? Just a thought... Are you running ac?
Old Oct 15, 2014 | 02:58 AM
Bubble Tech's Avatar
I would run a spacer or weld a spacer onto the alt bracket to push the alternator forward
stickmantijuana
MoTeC
Sep 10, 2015 07:58 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
