Try this out (kinda scary)
Old Jul 14, 2002 | 03:47 PM
P'cola FD's Avatar
Hamado things my way!
Next time you're changing your oil, drain the oil out, leave the filter on, fill it up, run it for a minute, and then drain it again. I work at a dealership where I get "free" oil, and when I change it, I flush it like this two times before actually putting the new filter and heavier oil in. Since there is so much old oil in the cooler(s) and lines, the first time you flush it, it will still be jet black. I really wish there was an easier and less wasteful way to do it, though. Just a suggestion.
On another note, I put some Mobil 1 gear lube in my transmission, and it is noticeably smoother.
--Danny
Old Jul 14, 2002 | 05:11 PM
djantlive's Avatar
Interesting. After I change the oil & filter, the oil is usually light gold or clear in color. I guess flushing the oil is a good idea once in a while too.
Old Jul 14, 2002 | 05:23 PM
rotorbrain's Avatar
fart on a friends head!!!
flushing is definately worth it. just dont do it too much. it would be like girls dousching too much. hahahaha.
Old Jul 14, 2002 | 06:30 PM
JONSKI's Avatar
5yr member, joined 2001
Have you tried using a better filter? I wouldn't know for sure, though, seeing as how I CAN'T EVEN GET MY ******* HANDS ON ONE! I SWEAR IT'S LIKE THE MANUFACTURERS DON'T WANT ME TO HAVE THEM! I'll probably need to resort to asking a forum member to mail me some. I'm probably asking too much when I ask for a Bosch Performance Oil Filter or a Fram X2. OH ******* WELL!
Old Jul 14, 2002 | 09:00 PM
djantlive's Avatar
Jonski, if you can't find the premium filters, just use Mazda OEM. I think they are very good.
Old Jul 22, 2002 | 02:53 AM
futurerexowner's Avatar
Ok if I were to switch to the Amsoil what weight should I use? I was on there website and a case of 20W-50 is around $94. Would this be a good weight for a little bit of Cali heat and the upcoming winter (a case will last a little while, 12 qts)
Thanks
Catlin M
Old Jul 23, 2002 | 04:00 AM
duboisr's Avatar
Amsoil is great check into being a dealer so you can get it at a discount .Use the same weight that you liked before , Think about running Amsoil 2 cycle oil to your oil metering pump with an adapter,Garfinkle has this set up.
Old Jul 23, 2002 | 05:31 AM
user 84205's Avatar
Since we are talking about flushing, I was just going to add DONT USE ENGINE FLUSH, its highly recommended here not to because in the rotary there are too many places for it to hide and it can really FRUCK up your engine...
Just for info
Jason
www.jt-imports.com
Old Jul 23, 2002 | 12:32 PM
P'cola FD's Avatar
That's a given, Jason. That flush is nothing more than kerosene, anyway. I just use fresh oil.
My question is would it be ok to flush with mineral oil, but fill up with synthetic oil?
Old Jul 23, 2002 | 02:45 PM
BlackR1's Avatar
Meesto Spakaro
just change oil more frequently... i change mine every 1500 and it comes out pretty clean... after i drain i just run a quart through the system to clean out any shiet and it works just fine.
Old Jul 23, 2002 | 03:18 PM
just quart?
is that safe?
Old Jul 23, 2002 | 03:31 PM
Street King's Avatar
*** Bless Texas!
No I think he pours an extra quart in after drianed, but not plugged. So the fresh oil pushes out the rest and is drained. Then oil bolt goes in and he refills.
Old Jul 23, 2002 | 04:53 PM
user 84205's Avatar
I was told several times to never mix the 2.
So I wouldnt recommend it....
Old Jul 23, 2002 | 05:26 PM
P'cola FD's Avatar
thanks
Old Jul 23, 2002 | 06:27 PM
sacabon's Avatar
Why don't you just drain the oil cooler at each oil change? That's what I do. It drains about an extra quart. Oil stays much cleaner
Old Jul 23, 2002 | 06:35 PM
RICKRX7's Avatar
Is there a drain on the cooler? I have never looked.
Old Jul 23, 2002 | 07:06 PM
P'cola FD's Avatar
Aha. That would be much simpler. How do you go about draining the oil cooler(s)?
Old Jul 23, 2002 | 08:31 PM
RTS3GEN's Avatar
The Man
The coolers have a clip that holds the end of the line into the receptacle. Just pull it out w/ a set of needle nose pliers and then jiggle the hoses off. You can even go get some brake parts cleaner spray and clean out the coolers every couple of months too to help prevent sludge from building up around the thermostat and clogging the coolers up. Just remember when you refill the oil you'll be about an extra quart low. And for the Amsoil, I road race about 6-8 times per year and have always used 20w/50. IF the car ever sees operating (in other words, always)temps this will ensure that the oil doesn't get too thin, especially on the eshaft bearings and the main bearing. This has also been known to solve some minor engine oil leaking behavior with thinner wt. oils ie 10W/30 or 10W/40. Another good prelube trick, if you don't use the car as a daily driver, is to pull the egi fuse before you start the car, especially if sitting for a few days, and crank for about 15 or 20 seconds. This will prime the oil pump and prelube the main bearing surfaces prior to engine firing. Only a couple extra minutes can save your bearings in the long run. Just my dime.
Art
Old Jul 24, 2002 | 09:57 PM
sacabon's Avatar
I drain my cooler a little differently than rts3gen. There is also a large bolt at the bottom side of the cooler. aluminum color. When you remove it a spring and another piece come with it. I think it may be a flow regulator. Anyways, it takes only a few seconds to remove it. On my car I cut a small section of the plastic below my cooler so oil could run directly ino a pan. I'm not sure what size the head is. I use a large adjustable wrench to remove it. After doing this a couple times I noticed a big difference in the time it took for my oil to turn into black goop.
Old Jul 24, 2002 | 10:02 PM
Mr. Stock's Avatar
1993 RX7 R1
That's very helpful.
I wondered if that shiny aluminum nut like thing can be removed from the oil coolers. I will try that next time.
Ed
alfred1976
1st Gen General Discussion
Oct 1, 2017 09:51 PM
sctRota
Old School and Other Rotary
Nov 10, 2015 12:57 PM
c0rpse
16
Sep 25, 2015 11:33 AM
Barry_Beef
Sep 22, 2015 06:36 PM
Barry_Beef
Sep 22, 2015 06:34 PM
