Dimpled instead of drilled Brembo Rotors
Just received my set front/rear of Brembo Rotors from the RX7 store. When I ordered them Jason told me that whomever does their/his machining no longer does drilled, only dimpled. I assume this helps reduce cracking?
Anyways, they still look great! Here are some pics I took last night off the car. More pics to come when I get them on.
http://flathat.woodstream.net/RX7/Brembo_Rotors/
BTW: my gf loves it when I take pictures of my new car parts on the dining room table...
K
K
All you're doing is taking out more of the heat sinking iron, and reducing heat transfer capacity. If you're into looks and not worried about track performance, I guess these are ok, but these dimpled slotted rotors won't do much for you...well they might help slightly in the rain...
Actually they do help.. But really only on the track. The let gasses escape off the pads through the groves & let the pad work better.
Same thing with X-Drilled.. People are moving to slotted rotors becuase they are more durable with the same benifits as X-Drilled..
-Zach
-Zach
dimpled rotors??? thats one of the dumbest things that ive ever seen
so now youve decreased the surface area of the rotor even further without being able to dissipate heat any better. the grooves already expell gases so the dimples dont do anything more than reduce the pads contact area with the rotor.
this is what i'd expect from a civic and not from an rx7
shame on you
shame on you
Trending Topics
shame on you
shame on you
Originally posted by phatmonky
Can you show me that just slotted will stop faster, fade less, and float just as little when hot??
Originally posted by zyounker
um, yeah kinda like the RX-8?????
I would hope mazda knows that those dimples don't work.. maybe you should email them.. looks like they are makeing a big mistake
-Zach
-Zach
gimme a break
look at the brakes on the rx-8 in this months road and track. r they drilled and slotted? i didnt think so
thanks for coming out though
i dont care what u want to buy for your rx7, im just saying that it isnt viable or effective.
Yeah those are for looks.
Right now the best productions brakes are on the Porsche 996 Turbo. I believe they are exotic carbon brake rotors and pads. $10,000 option, I think. If I recall they were solid faced rotors...?
Talk about being able to stand up to the heat.
SleepR1: well carbon or ceramic disks/pads would be optimal.. and you would not want them to be X-drilled.
As for just looks, i disagree. I have seen various manufactures come out with setups like this. so i doubt it is just for show.. especially when the no longer carry X-drilled rotors..
And further more, did it occur that cars in auto shows have every option that the engineers would love to put on a car.. but when they make it production ready, they have to cut alot of corners to make it meet expected costs???
-Zach
-Zach
ok, upon looking at some of the other rotors out there.. i realized that most are x-drilled & slotted.. not "dimpled"
So, why would they not just drill through??? it doesn't make sense.. I would assume it has some benifit.. but i don't know.
-Zach
-Zach
concept cars r built to grab your attention... fancy brakes, huge rims and funky designs attract attention. it has very little to do with the actual performance of the car. its only designed to guage peoples interest.
now crossdrilled and slotted rotors do look pretty cool but many of them do not aid in braking, they rather impede it. the only way that you will get an improvement in a crossdrilled and slotted rotor is if it was designed that way from the manufacturer, is much larger than stock in diameter and comes with a caliper that accomodates a much larger brake pad. this way you get good gas evacuation, better heat dissipation as well as minimizing contact surface loss. they sometimes even increase it even though they're x-drilled and slotted through use of a much larger pad and rotor. all these factors come into account only when your willing to spend alot of money on an entire brake upgrade such as the brembo big brake kit which i currently am running.
these rotors that we r currently speaking of r particularily faulty due to the fact that they do not come x-drilled and slotted from brembo. a third party does this process. do u know why they're no longer offered in x drilled but dimpled now?... its because all the rotors were cracking. this happens because the drilling is done after a special coating and treatment is applied to the rotor from the factory. drilling them after only weakens them. when a factory decides to x-drill they do it first and then apply the coating and treatment to ensure both durability and longevity. im not sure about the durability of these dimpled ones but those r the facts.
sorry about the long post
Here are some pictures of my new brakes:
http://www.fatboyraceworks.com/~ndahl/brakes/
Those are EBC rotors. They are "cross pitted" and "sport slotted" (not machined all the way through).
Would you believe they have a warranty? But only if you use EBC pads, of course.
-Zach
-Zach
Originally posted by FavBandDMB
Can I get Brembo rotors that are only slotted at the factory? Or do they come solid-faced only?
Awh, I imagine Kyle likes the look of dimples and slots, and the purchase has little to do with actual performance
When you get me on the track, I'll swap back out to the stock rotors if I get nervous about cracking since they only have 30k miles on them.
K
Kyle,
I imagine the EBC rotors will be fine out on the track with HP Plusses. The dimples shouldn't crack at all...
Try to get in on the Porsche CIR PCA Drivers Ed at Putnam Park Apr 27/28. It's a good deal, and the in-car instructors are great! I know of one particular FD Rx7 owner who will be an instructor during this event--HINT--he's the moderator of this forum...
See ya at the track!
ceramic brakes will never be on the street, porsche never came out with that option beacuse of what i recall to be "catistrophic brake failure", and as for xdrilled, ever noticed how its lined up with the ventilation? its so heat can escape that way, and as for the slot, its to take off glazing, o and another thing, brakes dont gas anymore
