How Tall Are You Guys?
Old Jan 20, 2002 | 07:05 PM
Just wondering how tall you guys(and girls) are. I have heard that the RX7 is rather cramped if you are over 5'10''. And as a side note none of the 3rd Gens had a tilt steering wheel option did they? I have made several test drives in the 3rd gen. (going to make a purchase in the next 3 months or so) and I seem to fit comfortably. I am 5'10-11''
Old Jan 20, 2002 | 07:21 PM
evot23's Avatar
Classy
5'6"...no tilt steering.
Old Jan 20, 2002 | 07:23 PM
Flybye's Avatar
It's never fast enough...
6'. No problems here.
Old Jan 20, 2002 | 07:26 PM
Rx7@Rocketship.com's Avatar
6'4" - Problems with headroom with a helmet on, and heel and toe is impossible for me even with a WideFoot pedal extension.
DI
Old Jan 20, 2002 | 07:31 PM
frank69m's Avatar
5' 11"-225 lbs. and wide shoulders...and it fits quite snug...no uncomfortable positions for me.
Old Jan 20, 2002 | 07:33 PM
Silex's Avatar
5' 11'' & 3/4 (196 lbs) . I'm exact ya know . Never had much of a problem here ana yes the tilt steering is a 'u better fit me' kinda deal, but if it works for your body then that works perfectly!
Old Jan 20, 2002 | 07:35 PM
SleepR1's Avatar
5' 9" 235 lbs
No Text
Old Jan 20, 2002 | 07:36 PM
Silex's Avatar
Don;t by shy Sleep...talk to us...we are all ears
Old Jan 20, 2002 | 07:50 PM
SanJoRX7's Avatar
uid 0
5'9" 170lbs, no problems fitting, but I do find heel and toe a bit awkward for some reason. My Impreza doesn't have this problem, so I'm not sure what the deal is :/
Old Jan 20, 2002 | 08:00 PM
c00lduke's Avatar
6'2" 130lbs, no problems at all.
~Luke
Old Jan 20, 2002 | 08:05 PM
Splinemodel's Avatar
wow you're skinny. I'm 6' 165lbs myself, and I have no problems at all. Actually, the car fits a lot better than do a lot of American run-of-the-mill sedans.
Old Jan 20, 2002 | 08:06 PM
maxcooper's Avatar
WWFSMD
Heel and toe with the stock pedals is a big PITA. However, it becomes very easy with the Widefoot gas pedal extension. Just put the ball of your foot on the brake pedal and roll your foot to the right to blip the throttle. The FD with the pedal extension is the easiest car to "heel-and-toe" I have ever driven. I got the small extension and it is all you need. The unit installs easily and is very nicely made. It may still be a problem if you are tall, but I don't know one way or the other as I am short (5'6"). This page has info on how to get one:
http://www.crookedwillow.com/product...e.htm#swaybars
-Max
Old Jan 20, 2002 | 08:08 PM
rynberg's Avatar
5'7" and 130 lbs, I fit great, even the non-tilt wheel is perfect
Old Jan 20, 2002 | 08:21 PM
JoeD's Avatar
5'7", and i fit just fine. dont know how i fit with a helmet though.
Old Jan 20, 2002 | 08:24 PM
JoeD's Avatar
Max, the pedal extentions look nice, but wont you run into problems of pressing the brake and gas at the same time if you have big feet??
Old Jan 20, 2002 | 08:28 PM
c00lduke's Avatar
JoeD
"wow you're skinny"
I bench close to 200lbs
~Luke
Old Jan 20, 2002 | 08:34 PM
JoeD's Avatar
JoeD
"wow you're skinny"
~Luke
huh?? that made no sense whatsoever.
EDIT: i get it....you have mistaken me for Splinemodel.
Old Jan 20, 2002 | 08:36 PM
suprfast's Avatar
5'8.5" 195lbs. i bench about 255 and leg press upwards around 650. im not fat ill check out the hemlet with me tomorrow.
kris
Old Jan 20, 2002 | 09:08 PM
Mahjik's Avatar
Mr. Links
Lightbulb
6' and 175lbs. No problems fitting in a Touring model.
Old Jan 20, 2002 | 10:11 PM
Chadwick's Avatar
Mr Sparkles
6'4" 245lbs. Had a problem getting comfortable with a helmet on until I installed a racing seat. With it mounted on the stock rail I can get to a perfect race postion with a helmet on and can still slide it back for the few days I take it on the road. The seat I choose dropped me down about a inch and a half. A 25mm spacer and 350mm steering wheel gave me all the leg clearance I needed, plus didn't require me to slide as far forward for good hand position.
Dan
Old Jan 20, 2002 | 10:17 PM
Touring FD3S's Avatar
5' 10" 195. no real problem here. Fits like a glove
Old Jan 20, 2002 | 11:26 PM
JONSKI's Avatar
5yr member, joined 2001
6'4" 155lbs in a touring
My legs touch the steering wheel.
I need to put the seat back and slouch a bit.
My groin starts to cramp after driving for over an hour.
Wouldn't trade it for anything.
Old Jan 20, 2002 | 11:32 PM
6' 240lbs Fits like a glove!!
Old Jan 20, 2002 | 11:34 PM
machinehead's Avatar
kortez
6'3" 225lbs, fits like a glove, but long drives will take thier toll.
Old Jan 20, 2002 | 11:45 PM
JeffShoots's Avatar
Dan
I'm 6'3" and 215lb, what seat did you use? I don't fit well with a helmet.
Thanks, Jeff
